Yay! got it running! |
Scott-thundercat |
Oct 31 2006, 08:26 PM
Member Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 |
so tonight i got it running- turned out the condensor wire was broken right below the condensor out of sight- i bought some when i first got the car but didnt put em on. so i changed the points and condensor (the old points also had a little corrosion on em which im sure was an issue too- saving em for emergency!) replaced another two fuel lines (the pressure plastic line from the pump up cracked! so i replaced the whole line all the way to the pump). sprayed carb clean down the injectors and also on the ends of em. cranked it and it fired up! didnt want to run much but it ran. im pretty sure the injectors need cleaning badly- so i'll put some gumout in there and see if it gets better. now i just need to wait till the 2nd when my bronze pedal bushings come in to get the brakes working (well that's being hopeful). since the brake pedal sticks so much you have to pull it back up by hand....
at least its running! thank god!!!! thanks for all the help guys. never did figure out why the pump all of a sudden started working today- i removed the ground for the relay board and cleaned all of them so maybe that fixed it.... |
So.Cal.914 |
Nov 1 2006, 12:44 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
It's always an attitude adjustment when it runs. Probably was the ground and while
your at it maybe do the one above the fuse panel under dash and the one back by the tail of the trans. I am sure you have done the one by the battery. |
ThinAir |
Nov 1 2006, 12:52 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 10th June 2024 - 04:45 PM |
