strange gear shifter parts, prior owner instal |
dmenche914 |
Nov 9 2006, 09:08 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
on my rear shift car, upon removal of the shifter, we found a small aluminum blcok, drilled toand attached to the shift plate (the part the shift lever pivots on in the tunnel) this moves the bushing bracket forward, and down inthe tunnel. Don't know why this modification was made, andyone seem this before?
SirAndy |
Nov 9 2006, 10:05 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
on my rear shift car, upon removal of the shifter, we found a small aluminum blcok, drilled toand attached to the shift plate (the part the shift lever pivots on in the tunnel) this moves the bushing bracket forward, and down inthe tunnel. Don't know why this modification was made, andyone seem this before? short shift kit? (IMG:style_emoticons/default/confused24.gif) by extending the lever below the pivot, you need less throw on the top of the lever to move the rod the same amount ... (IMG:style_emoticons/default/idea.gif) Andy |
dmenche914 |
Nov 10 2006, 08:59 AM
that might be it, I figure no other reason for it being there, and that is certainly what it looks like it does.
Lo-Fi Version | Time is now: 11th June 2024 - 10:41 AM |
