How do you remove these?, door closed switches |
thomasotten |
Nov 12 2006, 04:48 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
It will only go this far, and when I look on the other side, it appears larger than the square hole.
Attached image(s) |
SirAndy |
Nov 12 2006, 08:48 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It will only go this far, and when I look on the other side, it appears larger than the square hole. you need to take the wires off first (on the back) then it'll come out in a slight angle ... (IMG:style_emoticons/default/smile.gif) Andy |
william harris |
Nov 13 2006, 07:49 AM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
This is very easy. The electrical connector spade is at the bottom of the switch. You can pull and angle it towards the inside of the car and remove it with the wire still in place. This helps as you might want to mark the position of the wires to reinstall. Or as Andy suggested, remove the speaker and fish up inside and pull the wires off and remove. Not much to it.
thomasotten |
Nov 13 2006, 08:10 AM
I got it out. Mine was stuck because the plastic was deformed at one of the contact points. Who has new ones?
william harris |
Nov 13 2006, 08:46 AM
I got mine at the local Porsche parts department.
Tobra |
Nov 13 2006, 09:37 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
One from a late model VW should fit, right down to the rubber seal
Lo-Fi Version | Time is now: 7th June 2024 - 08:53 AM |
