Clutch Tube repair, Pictures needed |
Trekkor |
Nov 16 2006, 04:28 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I want to open up the center tunnel to inspect and repair the broken clutch cable tube. It has broken away and that has contributed to the clutch cable fork that attaches to the pedal bending and breaking during my last track day.
When the tube breaks, the cable pulls from an angle and creates uneven stress on the fork. Also, a broken tube make it difficult to properly adjust the clutch. I would like to see a picture showing an access hole above the tube location. thanks KT |
Rand |
Nov 16 2006, 04:38 PM
Try a search in the classics for "clutch tube." There might be a thread in there with some good pics.
I don't know if it has the pic you're looking for but check this: clutch tube repair |
Mueller |
Nov 16 2006, 05:27 PM
cutting the center tunnel for access is a hack job (IMG:style_emoticons/default/smile.gif)
seriously, you only need to drill out the spot welds on the side of the tunnel and re-weld.... I think Jeff Bowlsby posted pictures of the repair I did on his Grasshopper car.... (IMG:style_emoticons/default/welder.gif) |
toon1 |
Nov 16 2006, 05:32 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
cutting the center tunnel for access is a hack job (IMG:style_emoticons/default/smile.gif) seriously, you only need to drill out the spot welds on the side of the tunnel and re-weld.... I think Jeff Bowlsby posted pictures of the repair I did on his Grasshopper car.... (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/agree.gif) that's what I did. pull the clutch and throttle cable before you weld, you'll be sorry if lyou don't. Ask me how I know! |
JeffBowlsby |
Nov 16 2006, 09:50 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Trek:
Go here to see the carnage of the hard/wrong way and then the easy/right way at the end of the thread. Clutch tube repair (IMG:style_emoticons/default/biggrin.gif) |
Krieger |
Nov 16 2006, 10:08 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Nice plate job for the firewall. I had to make both those repairs as well.
SGB |
Nov 16 2006, 10:37 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
here is more "insight" courtesy of DD
914_center_tunnel |
Trekkor |
Nov 16 2006, 10:41 PM
Thanks for the link.
I want to fix this tomorrow. KT |
Trekkor |
Nov 16 2006, 10:53 PM
If I do cut a hole, it will be concealed by the center console.
The hole doesn't bother me. What kills me is, because I don't street drive the car so much anymore, it only breaks down at the track/autocross. (IMG:style_emoticons/default/headbang.gif) KT |
Trekkor |
Nov 16 2006, 11:11 PM
My clutch tube is SO loose in there, that when I depressed the clutch pedal the shifter would move. (IMG:style_emoticons/default/ohmy.gif)
I inspected and the top of the clutch tube has been worn to bare metal right under the shifter. It's been loose for quite some time. At least since the Laguna weekend two months ago. KT |
JeffBowlsby |
Nov 16 2006, 11:29 PM
Once you see how easy it is to fix, its way more trouble to cut the hole, and its unecessary. Pull the cable and shifter, locate and drill the holes on the side tunnel wall, weld, reinstall shifter and cable. Done. Very easy.
Trekkor |
Nov 16 2006, 11:45 PM
How are you keeping the tube firm against the inner surface of the tunnel before welding?
Mine is all over the place in there. (IMG:style_emoticons/default/confused24.gif) KT |
JeffBowlsby |
Nov 17 2006, 12:04 AM
C-Clamp it to the side of the tunnel through the shifter access hole.
Trekkor |
Nov 17 2006, 12:10 AM
So.Cal.914 |
Nov 17 2006, 12:15 AM
I heard a good idea for preventive measures, at the fire wall/clutch tube weld
a large fender washer to the firewall over the clutch tube and then to the tube itself. This reinforces that connection point and spreads the stress out over a larger area. Just FYI. |
Trekkor |
Nov 17 2006, 12:29 AM
Yes, I'll be doing something like that, too.
KT |
John |
Nov 17 2006, 12:41 AM
I believe at the rear firewall, I used a 1/2" washer with a flat spot ground on it (to fit against the floor seam).
I did the drilled spotweld trick. to secure the front of the tube as well. Real easy fix. The one location I am sort of concerned with is the weld location between the seats. I couldn't figure out a way to get to that one to reweld it. The tubes were once welded in 3 spots: 1. At the front of the tube 2. In the middle of the tube 3. At the rear of the tube (firewall). |
KenH |
Nov 17 2006, 01:28 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
In held one in place with a metal cable clamp around the tube and then bolted inside the tunnel with just a bolt & nut coming through the side of the tunnel - no welding.
Ken |
McMark |
Nov 17 2006, 03:42 AM
The tubes were once welded in 3 spots: 1. At the front of the tube 2. In the middle of the tube 3. At the rear of the tube (firewall). This is true, EXCEPT that they were never welded. No tube is welded to the car. The clutch tube, the engine lid release tube are all brazed. Welding has the potential to protrude into the tube as it melts. Any protrusion into the tube will wear cables FAST! Welding clutch tubes makes me nervous, but it's really the best solution as long as you're careful. The brazing is also one of the reasons that a fender washer is necessary at the firewall. You can weld over brazing, so in order to repair that section you either have to redo the braze, remove all the brazing material then weld, or use a fender washer that extends beyond the brazing. |
maf914 |
Nov 17 2006, 07:30 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Mark, Good points about brazing versus welding. (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 31st May 2024 - 08:11 PM |
