Cylinder heads, 1.7-1.8 or 2.0 |
roadpilot |
Nov 22 2006, 10:42 PM
Newbie Group: Members Posts: 1 Joined: 3-July 05 From: Grangeville, Idaho Member No.: 4,361 |
(IMG:style_emoticons/default/dead horse.gif) How can you tell the difference between 1.7 heads, 1.8 heads ?.I know that the 2.0 heads have the 3 stud pattern. I have a couple sets and am a little confused. Many thanks ahead of time to all replies.
Borderline |
Nov 22 2006, 11:14 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
The 1.7L has smaller valves (39mm intake and 33mm ex) and also has smaller "register" diameter (it will accept a smaller cylinder diameter than the 1.8L). the 1.8l has 41mm intake and 34mm ex. Hope this helps.
Borderline |
Nov 22 2006, 11:16 PM
oops I almost forgot.... (IMG:style_emoticons/default/welcome.png)
McMark |
Nov 22 2006, 11:33 PM
Check out this web site. (IMG:style_emoticons/default/biggrin.gif) The biggest clue is that 1.7/1.8/Bus2.0 heads have four intake manifold studs and 914 2.0 heads have three intake studs. Otherwise you have to compare the combustion chambers. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:21 PM |
