michaelt55 |
Graduate of Life's experiences ![]() ![]() Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None ![]() |
Ok, tried to put my MoMo steering adapter on this weekend and it seems to lack about 1/18 inch to provide contact with the steering column. I have that gap and now my horn doesn't seem to work. Do I remove the c clip on the column to allow further travel? Any one had similiar experiences?
Michael |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Hi Mike,
What year car?? Please give the info on the sticker. Porsche changed columns in late 72 or so. This could effect which adapter you need. B |
Brad Roberts |
Mike,
do you know some of the other 914 people in the Houston area? I know your are outside of Houston, but we have a pretty good group in Houston! B |
michaelt55 |
Hi Mike, What year car?? Please give the info on the sticker. Porsche changed columns in late 72 or so. This could effect which adapter you need. B I specified to the company, its a 73..so I guess I better check and make sure its not for a 72 or earlier!! Thats a thought, thanks Brad. Michael |
Brad Roberts |
It could be an early early (Sept. 72) that sold as a 73 in 73. It *could* have the early column.
B |
Lavanaut |
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest ![]() |
I recently installed a momo adapter in my '74, and have a gap as well. I've read elsewhere that this is normal. I included a (bad) pic below of mine, is this the gap you're talking about? (IMG:style_emoticons/default/idea.gif)
Attached image(s) ![]() |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
If you have a 1/2" gap or so, you probably have a 911 hub.
Lavanut, yours looks correct. Brad, isn't the change in Hubs for 70 & 71 only - 72 + use the same, no? |
Brad Roberts |
which ever column doesnt have the wiper switch.. (that is early..LOL)
I forgot which year they moved the wiper switch. Been a LONG time since I have owned a early non 9146 car.. B |
HeloMech |
Go Ahead, Get Pistoph! ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California ![]() |
didn't have a wiper switch? Where was it before it was there on the column?
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
On the dash, pushed it to get washer fluid flowing if I remember right. When they broke, the washer fluid will leak on your leg.
pfierb |
oldest member ![]() ![]() ![]() Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 ![]() |
The MOMO part number should be 8002 for your car
michaelt55 |
Lavanaut...
thats identical to mine....and it is a 8002 adapter Michael |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
mine too...
if you are really anal... you can move the column surround forward a bit.... pull the column switches, pull the big allan bolt holding the column surround in... pull the lower dash... now tap the back of the column shroud from underneath (its why you removed the lower dash) tap it with a block of wood and a hammer until you pick up that 1/8" you would like (IMG:style_emoticons/default/smile.gif) AA |
Lavanaut |
Lavanaut... thats identical to mine....and it is a 8002 adapter Ok, so the small gap isn't of any concern, but naturally the fact that your horn doesn't work is. The two aren't realted though. I had just a single wire that I removed from the stock wheel that I fed through the hub adapter, and clipped to the back of the Momo horn button. The horn button has a brass-looking contact on the back, when I installed the button in the adapter I made sure to put that side in first, so that the metal contact was pressed/wedged firmly up against the hub adapter. Worked with no issues on the first try. My hub adapter came with no instructions at all, just a piece of paper that said, "WARNING! READ INSTRUCTIONS COMPLETELY BEFORE INSTALLING"...and nothing else. (IMG:style_emoticons/default/av-943.gif) I took a bunch of pics during my install, let me know if there's something you're not clear on..I'll post pics if I think it'll help. Lava |
michaelt55 |
by all means, please do...I just want to know how you hooked up the single horn wire that grounds out to the hub...
Michael |
Lo-Fi Version | Time is now: 3rd July 2025 - 08:50 PM |
