| Trekkor |
Dec 6 2006, 07:25 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I was goofing around with the brake wiring at the pedal switch.
(IMG:style_emoticons/default/dry.gif) ( calling all gremlins ) (IMG:style_emoticons/default/vampire.gif) It blew the fuse and now the relay buzzes and the signals/hazards are non-op. I tried another relay, it buzzes louder. Fuses doesn't blow. What have i done? How do I fix? KT |
| SirAndy |
Dec 6 2006, 07:28 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,454 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What have i done? How do I fix? what year is your car? got the door-light buzzer ??? maybe that was broken and you just fixed it. close yer doors! (IMG:style_emoticons/default/biggrin.gif) Andy |
| DanT |
Dec 6 2006, 07:30 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
| JPB |
Dec 6 2006, 07:50 PM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Let me help poor troubled brother. Just pull the thing out and all its wires, place in a burn barrel and light. Problem solved.
(IMG:style_emoticons/default/beer.gif) Less is more!! |
| Dave_Darling |
Dec 6 2006, 08:03 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Check yer grounds!!
And make sure you didn't knock any wires off of anything. --DD |
| Trekkor |
Dec 6 2006, 10:45 PM
Grounds are good. This is killing me.
I need my blinkers. KT ( help ) |
| Trekkor |
Dec 7 2006, 10:25 AM
| Trekkor |
Dec 7 2006, 11:34 PM
Nobody has a clue...C'mon!
KT |
| DanT |
Dec 7 2006, 11:46 PM
Nobody has a clue...C'mon! KT Trek, if you go to the dark side you won't need blinkers (IMG:style_emoticons/default/biggrin.gif) |
| Trekkor |
Dec 8 2006, 12:28 AM
When it rains, they let us out the windows up and use the turn signals as "point-bys".
During the "sighting laps", guys that know the line use the hazards. Plus, I still want to stay street legal. KT |
| Dave_Darling |
Dec 8 2006, 09:22 AM
Check the fuses, make sure you didn't knock any wires off anything, and re-re-re-check your grounds.
--DD |
Lo-Fi Version | Time is now: 7th March 2026 - 01:39 AM |
