| pbanders |
Jan 7 2007, 12:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
It may be that what I found is specific to my 914, but from what I can tell, this issue should apply to all 914's, unless they have a different engine relay board than mine.
In a thread on the PP board, I report (very long) on recent things I've done while chasing down idle instabilities with my car - the main one being a large drop when I add electrical load (e.g. lights). While tracking this problem, I found what appears to be a signficant design flaw in the charging system. First, some background on the charging system. See the following URL for an excellent description and troubleshooting guide for VW-based charging systems: http://www.ratwell.com/technical/ChargingSystem.html I used this article as my guide when tracking down the problem I describe. A properly-operating charging system supplies sufficient current from the alternator under all running conditions (except starting) to power the car and to keep the battery charged. The voltage regulator works with the alternator to make this happen. The voltage regulator accomplishes this by measuring the voltage of the battery and controlling the voltage put out by the alternator. This means that when the car is running, the alternator voltage will always be somewhat higher than the fully-charged battery voltage, to keep it charged. A fully charged auto battery produces about 12.6 to 12.8 V. Even a small decrease in battery voltage indicates that it is not in a fully-charged state. From the article referenced above, a battery at 12.35 V is only about 50% charged, at 12.0 V its at 25% charged, and at 11.8 V it's completely drained. When your charging system is working correctly, your system voltage will be at least at 12.8 V or greater. For the voltage regulator to work properly, it has to have the correct ground reference. If you look at the following diagram of the 914's relay board: http://www.pelicanparts.com/914/parts/Elec...lectric_73E.jpg .... part number 4 is the voltage regulator. Note that the D- connection, the ground reference, is connected to the case of the voltage regulator, which is shown connected to ground. BUT WHERE IS IT GETTING THE CASE GROUND? The relay board is made of PLASTIC. The screws which hold the voltage regulator to the relay board do not connect to chassis ground. As a result, the current path to ground for D- has to go through either the alternator or through the voltage regulator itself. I've measured the resistance to ground of D- on my car, and I got a value of 4 ohms. When the car is running, this resistance causes the voltage measured at D- not to be zero volts (as it should be, as per the reference I provided above), but to float to -1.1V. This causes the output of the voltage regulator to never exceed about 12.0 to 12.2 V, preventing the battery from ever charging to more than about 50% of a full charge. I did some further measurements of the resistance of D- to ground. If I pull the alternator plug from the relay board, the resistance increases to about 100 ohms. If you follow the current path to ground, you can see that it now goes through the voltage regulator, through the D+ connector, and though the alternator warning light circuit - which has a bulb in it that has about 100 ohms of resistance. If you open that circuit, you get no path to ground - the case of the voltage regulator isn't grounded. I connected a short ground wire between the voltage regulator case and chassis ground. Now, I read 13.0 V or greater under all running conditions, DF is at about 5 to 6 V when idling, and my battery stays charged to 12.8 V. The charging system is now working as it should have. EDITED: DON'T DO THIS. The cause of my problem is a bad alternator ground. D- is grounded to the case, and the case is strapped to chassis ground. DON'T PUT A WIRE between the voltage regulator and ground if you have a bad alternator ground like I do. Why? Because ALL OF THE CURRENT will now flow through the jumper wire - as much as 20A or more with high beams on. You could start a fire or worse - DON'T DO THIS. The question here is - is this common to all 914's, or is my car somehow different? If your voltage regulator is as mine is, connected only to the plastic relay board plate, and with no case connection to ground, then I see no way that your system should be any different from mine, and you should be seeing a lower charging voltage than is needed to keep your battery fully charged. I'd like to see some readings from other 914 owners cars. Here's what I'd like for you to measure, it only takes a few minutes with a simple digital voltmeter to take the readings. 1. With the ignition switched off, measure the resistance from the case of your voltage regulator to a chassis ground. If your charging system is set up correctly, you should read about 0.1 ohms. Anything more than 0.5 ohms is suspect. 2. Remove your relay board rain cover, and start the car and let it idle, headlights off, heater/blower fans off, stereo off. The alternator connector is the three-pin connector on the side of the relay board. Set your DMM to DC volts and measure the voltage between a chassis ground (there's a ground connection on the firewall beside the relay board that's nearby) and each of the pins (you can stick a probe down beside the wire into the connector and contact the pin easily). Here's what you should get: D+ (pin that's nearest to the front of the car: greater than 12.8 V, no more than 14 V D- (next pin down, brown wire): no more than 0.1V DF (next pin down): about 5 V or so (depends on the electrical load of the engine and the charging state of the battery) If you don't get the results above, then your car has the same problem as mine did. A simple ground jumper between a chassis ground and the case of the voltage regulator fixes the problem. Let me know what you find. Also, if my analysis here is wrong, tell me where I've gone astray. If there's another way the voltage regulator case is grounded on your car, or your relay board is different, let me know. Thanks! |
| Spoke |
Jan 7 2007, 12:38 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,373 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
My 74 has a brass ground strap from the alternator case to chassis ground.
You are correct that some ground strap is needed on the alternator for proper operation. Spoke |
| pbanders |
Jan 7 2007, 01:06 PM
My 74 has a brass ground strap from the alternator case to chassis ground. You are correct that some ground strap is needed on the alternator for proper operation. I'm not talking about the alternator case ground. I'm talking about the voltage regulator case ground. Not the same issue. |
| rhodyguy |
Jan 7 2007, 01:51 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
put this one in the classic thread section. the wire cured the idle fall off as things are turned on?
k |
| sportlicherFahrer |
Jan 7 2007, 02:12 PM
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
I will have to check my car out. I have a nasty idle drop when my loads are on, and with everything on, my voltage guage shows about 11.5. Hopefully this will be a fix!
| SGB |
Jan 7 2007, 02:17 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I also pondered this same question many moons ago on PP. As I recall, I stopped at "where is the VR ground?". Even the mighty DD did not know. I think that you are onto something, although I never did add a ground as you did, I ALMOST WAS going to now, BUT THAT WOULD BE WRONG!. Thanks! (IMG:style_emoticons/default/smile.gif)
| wilchek |
Jan 7 2007, 02:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
where did you attach the wire on the voltage regulator. The case is smooth. Did you just loop it around the case? Soider it?? Any pics would help.
Are one of the the three pins ground. Would it work to attach a wire to one of the pins if one of them is a ground connection?? Also, I have a digital voltage regulator not the bosch mechanical unit. Any idea if this will still work. Thanks for the info |
| pbanders |
Jan 7 2007, 03:21 PM
where did you attach the wire on the voltage regulator. The case is smooth. Did you just loop it around the case? Soider it?? Any pics would help. Are one of the the three pins ground. Would it work to attach a wire to one of the pins if one of them is a ground connection?? Also, I have a digital voltage regulator not the bosch mechanical unit. Any idea if this will still work. I took a 6" section of 14 ga copper stranded wire (brown casing - for ground) and crimped an eylet terminal to each end. One end I connected under the screw that holds the relay plate onto the car (chassis ground). The other end I connected under one of the two screws that hold the voltage regulator on to the relay plate. EDITED: DON'T DO THIS. Turns out I had a bad alternator ground strap or connection. Don't add a wire to ground your VR case. If you have an alternator ground fault, ALL OF THE CURRRENT supplied by the alternator will flow through this jumper wire, 20A or more! It could start a fire. DON'T DO IT. I have three voltage regulators, two of the OEM mechanical type, one that is a solid state aftermarket replacement - same as your digital voltage regulator, I assume. The fix worked with both types. I'm using the solid state one, because it regulates the voltage more closely. Apparently, Bosch makes a solid state plug-in replacement, the p/n is 0 192 062 007, it's supposed to be very good, according to this reference: http://www.ratwell.com/technical/ChargingSystem.html I'm going to find one and try it out. |
| pbanders |
Jan 7 2007, 03:26 PM
put this one in the classic thread section. the wire cured the idle fall off as things are turned on? Actually, it doesn't!! I thought it would, but now I understand why it doesn't, I got into it in detail in my posting on the PP board. What this fix does is to give you a charging system that actually keeps your battery at full charge, instead of about half charge - assuming you have the same voltage regulator ground issue my car had. The idle fall off with increasing electrical load is still there - it's due to drag on the motor from the alternator - the only difference is that now you're battery is charged to 12.8 V instead of 12.2 V or less. Read what I did to minimize the effect of loading in the PP board posting. I think there's got to be more to it than I've found so far. I can't believe that every 914 out there lacks a proper voltage regulator ground, and is only charging the battery to about 12.2 V. There must be an alternate ground path in some cars, or something else I'm missing. EDITED: DON'T ADD A WIRE TO GROUND FROM YOUR VR CASE - SEE MY EDIT ABOVE |
| John |
Jan 7 2007, 03:36 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I believe that this is a breakthrough that I have not yet heard about, but makes complete sence.
For a long time (when I was running a TIV, I had the same issues. Just barely above 12.0 V without any loads and just below 12.0V with loads. All other cars seem to have 12.8V and somewhat smaller drops with loads. You are exactly correct that in stock configuration, the case of the Voltage Regulator was not grounded to the chassis. Good job with this one. A simple jumper wire with eyelets on both ends (just as you describe) could easily solve the issue at hand. I wish I could try this one out, but alas, it is too late for me. I have gone to the dark side (-6 conversions). |
| pbanders |
Jan 7 2007, 05:15 PM
Just want to update by saying that after driving around today, my battery is still at 12.9 V. This is the first time in the 25 years I've owned the car that the battery has stayed at a fully charged level, and I've been through about a dozen batteries, 5 or 6 voltage regulators, and at least two alternators.
DON'T DO THIS, DON'T ADD A WIRE TO GROUND YOUR VR CASE, SEE MY EDIT ABOVE |
| SGB |
Jan 7 2007, 05:22 PM
Thats what I'm gonna do, just crimp a couple of u- shaped ends on a 10 ga wire and ground from the VR attachment screw to the ground pont on the side hidden behind the relay cover...I DID NOT DO THIS!
| scotty b |
Jan 7 2007, 05:35 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:style_emoticons/default/clap56.gif) Awesome find! (IMG:style_emoticons/default/clap56.gif) Kind of amazing this has been going on for 30+ years and no-one has checked into it until now (IMG:style_emoticons/default/blink.gif) As many times as VR's have been replaced none of us had the lightbulb come on (IMG:style_emoticons/default/headbang.gif)
| Hammy |
Jan 7 2007, 05:36 PM
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California |
Just want to update by saying that after driving around today, my battery is still at 12.9 V. This is the first time in the 25 years I've owned the car that the battery has stayed at a fully charged level, and I've been through about a dozen batteries, 5 or 6 voltage regulators, and at least two alternators. Do you have a picture of your regulator ground set up? |
| pbanders |
Jan 7 2007, 05:56 PM
Thats what I'm gonna do, just crimp a couple of u- shaped ends on a 10 ga wire and ground from the VR attachment screw to the ground pont on the side hidden behind the relay cover... It won't hurt anything if you just go ahead and do it, but spend a minute first and check to see if you really have a problem. Check the resistance between the voltage regulator case and chassis ground first - if it's under 0.5 ohm (closer to 0.1 ohm), then the extra ground isn't needed. If you do find that it's grounded already, let me know. I'd like to figure out where it's getting the chassis ground from. |
| pbanders |
Jan 7 2007, 05:58 PM
EDITED - REPLY REMOVED, DON'T ADD A GROUND WIRE TO YOUR VR CASE
| JPB |
Jan 7 2007, 06:05 PM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Specially for someone as imaginatively impaired as myself. (IMG:style_emoticons/default/blink.gif) |
| 904svo |
Jan 7 2007, 07:56 PM
904SVO ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Thats what I'm gonna do, just crimp a couple of u- shaped ends on a 10 ga wire and ground from the VR attachment screw to the ground pont on the side hidden behind the relay cover... It won't hurt anything if you just go ahead and do it, but spend a minute first and check to see if you really have a problem. Check the resistance between the voltage regulator case and chassis ground first - if it's under 0.5 ohm (closer to 0.1 ohm), then the extra ground isn't needed. If you do find that it's grounded already, let me know. I'd like to figure out where it's getting the chassis ground from. I'm getting my ground from the grounding strap from alternator to engine case see post #3. |
| wilchek |
Jan 7 2007, 09:47 PM
dumb question. My DMM has a bunch of OHM settings. Which one should I use. I have 2000K, 200K 20K, 2000 and 200. Also, any idea if the center console gage is accurate. I have always had 13 volts changing when nothing was on and around 12 with lights and heater.
| messix |
Jan 7 2007, 09:52 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
there is a ground on the relay board on mine. grounds to screw near back of board from a spade term at the back left of the relay board. this should also provid ground for the VR.
Lo-Fi Version | Time is now: 14th April 2026 - 06:10 AM |
