> Peedal wobble
ws91420
post Feb 2 2007, 10:42 AM
Yes I have one a Lensley 914
From: Ruther Glen,VA (halfway between sticks and civilization)
The gas pedal on my 73 goes off to side when pressed vs straight back. I have not had time to look at it. What may be the cause and where should I look?
Replies(1 - 4)
Eric_Shea
post Feb 2 2007, 10:45 AM
PMB Performance
Broken hinge at the base and/or broken throttle crank on the assembly.
TravisNeff
post Feb 2 2007, 10:46 AM
The hinge is rusting out. you will need to replace the pedal.
I did a lowbucks repair on one of my 914's a long time ago by using a hinge from a hardware store & little cutting and bolted it to the OE floor locationa and drilled 2 holes on the pedal to bolt it to the hinge.
DanT
post Feb 2 2007, 10:49 AM
Going back to the Dark Side!
pedal from a 964 works perfectly and it is less than $10 brand new from Porsche. (IMG:style_emoticons/default/smile.gif)
The mounting holes are spaced slightly differently and require just a bit of adjustment. Otherwise a direct bolt up.
Eric_Shea
post Feb 2 2007, 11:23 AM
PMB Performance
Got a part number?
- Lo-Fi Version Time is now: 26th October 2026 - 05:45 AM
