How can I tell if a Boge strut insert is good? |
rhcb914 |
Feb 4 2007, 09:10 AM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
I just replaced my rear KYB's and front Boge's with Bilsteins. The KYB's I could tell were good since they are gas charged when I pressed the shaft down it came back up. I know the Boge's aren't gas charged so how can I tell if they are still good? When I press them down there is signigicant resistance, same with pulling the shaft back up.
-Rob |
Eric_Shea |
Feb 4 2007, 03:38 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE When I press them down there is signigicant resistance, same with pulling the shaft back up. Then they're more than likely good. Both should be the same. Make sure there's no fluid leaks on the shafts. The resistance test you did is the way I gauge all my hydraulic shocks. |
rhcb914 |
Feb 4 2007, 07:13 PM
That's kind of what I figured. They look in good shape and I can't see any leaks.
Thanks! |
Lo-Fi Version | Time is now: 16th June 2024 - 10:34 PM |
