Hard right=STALL, :) |
redshift |
Nov 22 2003, 05:27 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Where is that problem? I can't find it in a search...
M |
Bruce Allert |
Nov 22 2003, 07:08 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
sounds like a wire movement = short. is that AAR frayed wire all fixed?
bruce |
redshift |
Nov 22 2003, 07:10 PM
AAR is out Bruce.
Found a couple things. Battery ground strap, nut hanging on last 2 threads. Grounds were cleaned everywhere else a while back, still good. When I was messing with the TPS earlier (in the dark) I knocked the tach wire off the coil. This leads me to where I think the problem was.. There are several wires that connect at the coil, all of them were shakey, re-crimped new connectors. Found (what I think) is the connector to the CHT (hey! I am new) lil phenolic block? Discoed. reconnected, and taped it up. Seems to be a runner. M |
Bruce Allert |
Nov 22 2003, 07:33 PM
the tach wire off the coil thingy did that to me too. Hard accel into a right corner & then nadda. Sure scares the carp outta ya when yer pullin out infront of a semi (insert smilie shit'n)
bruce |
Bruce Allert |
oh ya... and good sleuth'n (IMG:style_emoticons/default/smilie_pokal.gif)
bruce |
redshift |
Nov 22 2003, 07:49 PM
Also notice since I adjusted the TPS, that the 2700rpm boop is now a 2900rpm boop..
ALL YOUR TPS ARE BELONG TO US! This kind of crap always happens to me on the weekend before a long trip.. heh M |
Qarl |
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Damn Miles! I better look for something a little harder to detect next time I decide to F with your car while you're sleeping!
redshift |
Nov 22 2003, 07:53 PM
That's ok, I engineered the brakes on all the new Lotus US models!
M |
Bruce Allert |
Nov 22 2003, 11:50 PM
QUOTE(redshift @ Nov 22 2003, 06:49 PM) ALL YOUR TPS ARE BELONG TO US! heh M Oh Gawd I can't believe you said that... yer one'a them (IMG:style_emoticons/default/pray.gif) aarrrrgghhhh (IMG:style_emoticons/default/burnout.gif) bruce |
redshift |
Nov 22 2003, 11:59 PM
You know Bruce... I cleared it up... but it still has that specific throttle-offish condition... the TPS sucks for sure.
New Thread! M |
Lo-Fi Version | Time is now: 8th June 2024 - 09:41 AM |
