Tough cold-starts w/chokeless Webers..., any secrets from you northerners? |
PinetreePorsche |
Feb 20 2007, 08:57 AM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
My 2.0 w/ Webers will fire, catch for an instant,and die. Each re-start, the instant stretches out, till, on the 4th try, it runs for maybe one second, and the 6th or 7th it goes for 2-3 sec, and maybe the 10th or 12th, it will stay running with lots of artful foot flutter on the gas. Less artful and it dies--until it has had about 15-20 sec of uninterrupted running with the foot flutter. Even then it needs just a slightly high rev, like 1800 (hate to do that when it's still cold), then, after another half min, I can let the foot off the pedal and it'll stay running. Then, maybe another 15 sec, I can lift my clutch foot and not have the extra load of the heavy oil kill it again (maybe keeping the revs at 1000 with my foot). Finally, after 2 min total I can get underway, if I over-rev it pulling away in 1st. Still, it will back-fart a bit if I gas it too much after a shift to too low a rev. By 5 min, as the heat starts to come out on the glass, it gets more normal. SO: you far northerners with carbs --what can I do with choke-less Webers to make this a kinder, gentler process? (Yes, if there's salt on the roads --last 3 weeks here-- I leave it at home. But the warm and rain are coming for 2-3 days, so it will get out again, and I'd love to do right by it.)
type47 |
Feb 20 2007, 09:36 AM
maybe a block heater? you know, the type you can use in the dipstick tube. what type of cam? maybe you can go back to d-jet (IMG:style_emoticons/default/biggrin.gif) . glad i have L and D-jet, starts no problem with a cold start injector... (IMG:style_emoticons/default/happy11.gif) although i will admit they have been undertarp with the recent weather but have been pleased at ease of start when it was cold.
by the way, the first tech inspection by the pca potomac is this coming saturday in fairfax, 9-2. you should drop by. |
r_towle |
Feb 20 2007, 09:57 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
My 2.0 w/ Webers will fire, catch for an instant,and die. Each re-start, the instant stretches out, till, on the 4th try, it runs for maybe one second, and the 6th or 7th it goes for 2-3 sec, and maybe the 10th or 12th, it will stay running with lots of artful foot flutter on the gas. Less artful and it dies--until it has had about 15-20 sec of uninterrupted running with the foot flutter. Even then it needs just a slightly high rev, like 1800 (hate to do that when it's still cold), then, after another half min, I can let the foot off the pedal and it'll stay running. Then, maybe another 15 sec, I can lift my clutch foot and not have the extra load of the heavy oil kill it again (maybe keeping the revs at 1000 with my foot). Finally, after 2 min total I can get underway, if I over-rev it pulling away in 1st. Still, it will back-fart a bit if I gas it too much after a shift to too low a rev. By 5 min, as the heat starts to come out on the glass, it gets more normal. SO: you far northerners with carbs --what can I do with choke-less Webers to make this a kinder, gentler process? (Yes, if there's salt on the roads --last 3 weeks here-- I leave it at home. But the warm and rain are coming for 2-3 days, so it will get out again, and I'd love to do right by it.) Clean the idle jets. Sound like dirty jets. When you start it, let it sit still for 2 minutes minimum at idle. It will cough a bit, but it should sit at idle if properly tuned, and all jets are clean, the right size. Check in this order. points/condensor (important that the points are perfect this time of year.) Valves adjusted. new plugs. All jets are clean, all jets are the right size (look at plugs when you replace them, they should be the brown of a perfectly coked marshmellow) Use premium gas, and dont let it sit so long that the tank has really old gas in it. Add gas antifreeze. In the real cold, they will be a bit hard to start, but you are experiencing a car that is out of tune, and dirty jets...all rolled into one. It gets pretty cold up here, and I just tune the car twice a year, and when I tune a car, I replace all the consumables...plugs, point, rotor, condensor... Sometimes I replace wires yearly I replace the distributor cap...it gets corroded on the inside. So, twice yearly tune up. new parts only...they are cheap Once yearly wires and cap replacement I think a tune up costs like 30 bucks total...twice a year...big deal. I assume you have no chokes on the carbs...you dont need them if you have some patience (2min) and wait each time you start it cold. Rich |
jd74914 |
Feb 20 2007, 10:03 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
maybe a block heater? you know, the type you can use in the dipstick tube. what type of cam? maybe you can go back to d-jet (IMG:style_emoticons/default/biggrin.gif) . glad i have L and D-jet, starts no problem with a cold start injector... (IMG:style_emoticons/default/happy11.gif) although i will admit they have been undertarp with the recent weather but have been pleased at ease of start when it was cold. by the way, the first tech inspection by the pca potomac is this coming saturday in fairfax, 9-2. you should drop by. My car had a block heater (IMG:style_emoticons/default/laugh.gif) It went right under the oil sump and was quite the interesting contraption. It got float tested though. (IMG:style_emoticons/default/happy11.gif) |
adamfl |
Feb 20 2007, 10:05 AM
Sail Away Group: Members Posts: 12 Joined: 5-September 06 From: RI Member No.: 6,772 |
I had a similar issue with my 1.7 w/ 2x40idfs when I first got the car, which had been sitting for 2yrs or so. It turned out the accelerator jets were completley gummed up. Cleaned them out and now after one pump of the gas the car fires right up on the first try, even if it's freezing out.
I'm looking forward to some rain here this week to clean off the roads so I can get out this weekend! Adam |
Spoke |
Feb 20 2007, 11:13 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I have dual IDF40's on my 1.7L and it is a bitch to get running in the morning. The car starts right up cold but needs constant throttle-blips to keep going.
Through the first 2 miles of operation, the car stutters a bit and runs better every moment until sufficiently warmed up. Spoke |
pin31 |
Feb 20 2007, 11:48 AM
Member Group: Members Posts: 398 Joined: 30-January 07 From: Newport, Rhode Island Member No.: 7,492 Region Association: North East States |
I've got the same problem starting when cold (74 2.0 w/40IDF).
Good suggestion on cleaning jets. I just hate to mess with them (the car runs great). The car is new to me and I haven't messed with the carbs (if it aint broke....) and I'm a little apprehensive. Any words of wisdom or tricks of the trade?? |
mudfoot76 |
Feb 20 2007, 12:34 PM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
Clean the idle jets. Sound like dirty jets. When you start it, let it sit still for 2 minutes minimum at idle. It will cough a bit, but it should sit at idle if properly tuned, and all jets are clean, the right size. (IMG:style_emoticons/default/agree.gif) I have a '73 2.0 w/44IDF, and it is tempermental when starting in the cold (40F and colder), but it will start and idle. I just let it sit for a couple of minutes and then the car is ready to motor without any drama. |
ClayPerrine |
Feb 20 2007, 12:52 PM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I only have one thing to say.....
Carburetors = 70 year old perfume atomizer technology. Weber Carburetors = Italian chokeless version of 70 year old perfume atomizer technology. (It doesn't get cold in Italy) Electronic fuel injection = High tech, modern, computer controlled technology. Put on Fuel Injection and be able to lean in the window and start the car cold in 20 degree weather. (IMG:style_emoticons/default/poke.gif) (Above does not apply to Mechanical Fuel Injection, it is friggin worse than carbs for cold start!) |
r_towle |
Feb 20 2007, 12:57 PM
I only have one thing to say..... Carburetors = 70 year old perfume atomizer technology. Weber Carburetors = Italian chokeless version of 70 year old perfume atomizer technology. (It doesn't get cold in Italy) Electronic fuel injection = High tech, modern, computer controlled technology. Put on Fuel Injection and be able to lean in the window and start the car cold in 20 degree weather. (IMG:style_emoticons/default/poke.gif) (Above does not apply to Mechanical Fuel Injection, it is friggin worse than carbs for cold start!) First off...clean them Have patience when you start the car, and the 70 year old technology will still work fine. and Clay...Show me a system, a total system, dollar for dollar the same that will produce the same results, I would be happy to do it. When IC systems that cost 1-2k...and what, 100 hours to install and tune..hell give me carbs for a few more years... BTW, I run stock FI on two motors..and I love it...starts fine. But...when you want to change the cam,,,you are forced to buy either carbs or some outrageous home brewed system that could work, could suck...might need to spend 100 hours on some web site to learn how to spend 100 hours tuning it.. I can still go buy carbs, and bolt them on,,,without thinking...and enjoy the drive. So (IMG:style_emoticons/default/poke.gif) |
ClayPerrine |
Feb 20 2007, 01:04 PM
My personal opinion on carbs.. They suck.. both literally and figuratively.
Injection will make more HP than a carb, and it will do so with far better fuel mileage. Yes, I have run both successfully on a type IV (before the six conversion). I can show you how to put a GM FI unit, complete with DIS, on a Type IV and it will run. You will have to build your own harness, but it works great. Cost me about 500.00 in parts from a wrecking yard. But, as I always say, It's your car, do what you want to it. |
jd74914 |
Feb 20 2007, 01:51 PM
My personal opinion on carbs.. They suck.. both literally and figuratively. Injection will make more HP than a carb, and it will do so with far better fuel mileage. Yes, I have run both successfully on a type IV (before the six conversion). I can show you how to put a GM FI unit, complete with DIS, on a Type IV and it will run. You will have to build your own harness, but it works great. Cost me about 500.00 in parts from a wrecking yard. But, as I always say, It's your car, do what you want to it. Really . . . I'd be very very interested to see how you did that. That seems like a relatively quick and dirty way to get semi-modern FI. (IMG:style_emoticons/default/chowtime.gif) |
degreeoff |
Feb 20 2007, 01:57 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Yeah mine was a bitch too. I got good at the artful throttle bit, I would turn on the ignition (hear my faucet pump run) and floor it to get gasoline in the bore then crank...(insert artful gas pedal) and in 20-30 seconds good to go....
I sure hope the six is better with the carbs then my 4 was..... |
KaptKaos |
Feb 20 2007, 02:04 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Don't forget that there are FI parts that are NLA. This will only get worse. Carbs provide an alternative to that problem.
BarberDave |
Feb 20 2007, 03:23 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Wait till April 1s/t it'll start a lot better then. Dave (IMG:style_emoticons/default/slap.gif) |
alpha434 |
Feb 20 2007, 06:36 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
WD-40
Eric_Shea |
Feb 20 2007, 07:23 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
MFI sucks... (IMG:style_emoticons/default/poke.gif)
I have dual 40IDA3C's. For me this is a standard operating procedure when cold starting the car to keep it lubed up in the winter. My carbs. are like new. 1. Let the fuel pump run for a few seconds to fill the bowls (I don't start it often). 2. Pump 10 times. 3. Crank and feather the throttle. |
911quest |
Feb 20 2007, 08:07 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
Now you know why later carbed Prosches came with a hand throttle
PinetreePorsche |
Feb 20 2007, 08:34 PM
Now you know why later carbed Prosches came with a hand throttle So is there a proceedure to put a cable-operated choke-like thing-y on our Webers, or would it be a whole different carb? -(s9igned) Pinetree--back again--and thanks for the tips, esp the jets, but I need instructions, too! |
Joe Bob |
Feb 20 2007, 08:58 PM
Lo-Fi Version | Time is now: 11th June 2024 - 08:14 AM |
