kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
I've got a set of struts that are off my car that I want to remove the balljoints from. These are the 911 type Boge struts that are not the clinch nut type. The pins are removed. Should the balljoint just pull off or is it pressed in. Any tips on removing them would be appreciated.
Thanks, Kev |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
once the pin or bolt is gone... a few taps with a rubber sledge (or slowly up the hammer size) to the a arm.. should knock the bj out.
i have the ball joint socket if you need to take ball joints off the a arm. |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
They are not pressed in. I usually replace them if I remove them. In such a case I don't care if I tear up the boots. I use a pickle fork.
Pickle Fork Kit |
Aaron Cox |
if you need a pickle fork, i have one of those too...
Lo-Fi Version | Time is now: 17th June 2024 - 01:02 PM |
