993 engine, back dating from VarioRam |
db9146 |
Mar 3 2007, 11:02 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Anyone know what it takes to back date a 993 engine from VarioRam to pre-OBD-II F.I.?
Potential cost? |
PRS914-6 |
Mar 3 2007, 11:29 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The basic engines are the same with a small difference in valve size.. The vario ram is very sought after in the 911 crowd but won't fit in a 914 without a hack.
It would be easy to swap everything with someone with a 911 and put cash in your pocket, probably about $500.00. You would just swap complete intakes, wiring harness, and computers. Should be a bolt in deal. The OBDI computer has chips that can be burned for cheap and the OBDII (96 up vario-ram) cost about a grand to reprogram and get rid of the Drive Block Immobilizer. Much easier with the 95 or less years. I bought a 95 for that exact reason. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:45 AM |
