> transmission fluid?
Fyrmdk914
post Mar 8 2007, 02:08 PM
Can someone please tell me what type and weight of gear oil I should use for the stock transmission in my '75 1.8? I knoq this has probably been in the forum before, but I need to know quickly. Thank you. (IMG:style_emoticons/default/unsure.gif)
Replies(1 - 19)
yarin
post Mar 8 2007, 02:13 PM
'14-X'in FOOL
QUOTE(Fyrmdk914 @ Mar 8 2007, 03:08 PM) *
The quick answer is SWEPCO 201. $39.95 from Paragon
Just received mine. For a more detailed answer comparing and contrasting all the possibilities check the history, its been discussed time and time again.
Fyrmdk914
post Mar 8 2007, 02:18 PM
QUOTE(yarin @ Mar 8 2007, 12:13 PM) *
Thanks for the quick reply, I will check the history.
Cap'n Krusty
post Mar 8 2007, 02:20 PM
Cap'n Krusty
Any good quality GL-5 should be fine. That's GL-5, not GL-4, GL-4/5, not some top-off crap, just plain GL-5. NO MOLY ADDITIVES!!!!!!! If they tell you it's all the same, take your business elsewhere. 75w90, 80-/90w140, whatever.
The Cap'n
spunone
post Mar 8 2007, 02:23 PM
Ok Kap and where do you buy your GL5 and it's name ?? Thanks
Fyrmdk914
post Mar 8 2007, 02:34 PM
Thanks Cap'n! Is this something that I can buy at a local auto parts store, or do I need a specialty shop?
TROJANMAN
post Mar 8 2007, 02:57 PM
Looks nice in pictures.........
you can buy it at Walmart or any FLAPS
I use Castro 80/90 gear oil
$3 a quart
Make sure you get the $5 tool to take off the tranny plug. And always take the fill plug off before the drain plug.
Hammy
post Mar 8 2007, 03:18 PM
mr. Wonderful
QUOTE(TROJANMAN @ Mar 8 2007, 12:57 PM) *
Walmart too?
TROJANMAN
post Mar 8 2007, 03:21 PM
checker
but you can get a really nice gun rack for your 914 at Walmart
BMXerror
post Mar 8 2007, 04:09 PM
QUOTE(TROJANMAN @ Mar 8 2007, 01:21 PM) *
checker
ZZZZzzzing!!! (IMG:style_emoticons/default/alfred.gif)
Mark D.
Fyrmdk914
post Mar 8 2007, 04:33 PM
What's the spring and ball bearing for on top of the transmission drain plug? And why do you need to remove the fill plug first?
Cap'n Krusty
post Mar 8 2007, 04:37 PM
Cap'n Krusty
That's NOT the drain plug. Put it back! The drain plug is low on the passenger side and requires, in most cases, a 17mm allen tool for removal (same as the fill plug). The Cap'n
jasons
post Mar 8 2007, 04:59 PM
Jackstand Extraordinaire
Cap'n whats wrong with the moly additives? Is that what the Swepco 203 has in it?
TROJANMAN
post Mar 8 2007, 05:01 PM
you remove the fill plug first, to make sure you will be able to fill the transmission once it's drained.
Cap'n Krusty
post Mar 8 2007, 05:28 PM
Cap'n Krusty
QUOTE(jasons @ Mar 8 2007, 02:59 PM) *
Your synchros operate on friction, moly additives are used to reduce or eliminate friction, you do the math ....................... I dunno anything about Swepco products. The Cap'n
Fyrmdk914
post Mar 8 2007, 07:38 PM
Okay, I admit my stupidity. What was the plug that I removed first? (you know, the one with the spring and ball bearing) (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty
post Mar 8 2007, 07:40 PM
Cap'n Krusty
Part of the shift lockout detent assembly. Ball first, then the spring, then the plug. 18 ft/lbs is plenty. The Cap'n
Tobra
post Mar 20 2007, 09:03 PM
Giving this a little bump and a question. Have heard various things with respect to synthetic oil in transaxle. I think I remember the Krusty One being opposed to synthetics and to regular changes, but he does not indicate that here.
It seems the synthetics are more slippery than regular dyno juice, but if they are rated for the appropriate viscosity would they be okay, so long as they don't have friction modifiers such as the moly stuff? If synthetics are okay, sorry to try and steer you wrong Mike, keep that stuff and I will give you a couple of stickers to match
wbergtho
post Mar 20 2007, 09:27 PM
I agree
Aaron Cox
post Mar 20 2007, 10:17 PM
Professional Lawn Dart
i use basic dino gl5 sludge (IMG:style_emoticons/default/smile.gif)
and it tends to get changed every year ish...
- Lo-Fi Version Time is now: 11th July 2025 - 01:12 PM
