> ? rear heater blower switch adjustment ?, it wont come on unless you hold up on the lever
orange914
post Mar 10 2007, 08:11 PM
http://5starmediaworks.com/index.html
the rear blower only goes on if i pull the console lever up as it is supposed to -but- i have to pull and hold it in the full up position, if it goes down a fraction the fan turns off. (IMG:style_emoticons/default/mad.gif) where is the switch and can it be adjusted?
i also just completed installing the misc. j and s-tube items to complete the heating system. does anyone know of a heat resistant tape or ? to seal for hot air pipe leaks?
Replies(1 - 1)
banger
post Mar 10 2007, 08:18 PM
The switch is on the lever itself. IF you take the lever out, you will see a set of contacts that moves, and grounds itself to the lever body. There is a nut you can tighten, and increase the tension on the lever, which should keep it up.
- Lo-Fi Version Time is now: 1st July 2025 - 04:17 AM
