| Ferg |
Mar 12 2007, 09:36 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Third time's a charm right? (IMG:style_emoticons/default/dry.gif)
Need to attempt to reseal the taco plate again tonight, here are my Q's. Do you put a set of crush washer between the case and main temp plate, too explain what I mean, two crush washers would then be underneath and touching the case? and then a set of the washers on the outside of the cover plate, so four washers total? Ferg |
| Bleyseng |
Mar 12 2007, 11:16 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
no washers between the case and the taco plate. They are to seal the nuts to the plate. (IMG:style_emoticons/default/piratenanner.gif)
| Ferg |
Mar 12 2007, 11:22 AM
no washers between the case and the taco plate. They are to seal the nuts to the plate. (IMG:style_emoticons/default/piratenanner.gif) thanks (IMG:style_emoticons/default/beer.gif) so only two washers total are used correct? Ferg |
| So.Cal.914 |
Mar 12 2007, 11:33 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Correct...
Lo-Fi Version | Time is now: 19th October 2026 - 07:28 AM |
