Return oil tubes on a 6 cyl. |
xsurfer |
Mar 18 2007, 03:39 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Using SILICONE Spray. instead of oil in conjuction with hose clamps and a spreader clamp made the job simple. I could not get the tubes to move with a reasonable effort without the SILICONE SPRAY.
Anybody know the correct way to install these things. They don't slide out too easy after you get them small enough to get between the head and the case? I've got oil on them as per shop manual. Thanks. |
ejm |
Mar 18 2007, 04:02 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
If you don't want to use pliers to grip the tube directly you can use hose clamps. Put the clamps on each section of the tube and grab the screw housing of the clamp with pliers. Less chance of crushing the tube if you use clamps.
burton73 |
Mar 18 2007, 06:03 PM
burton73 Group: Members Posts: 3,549 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Look at the pelican parts story on these as well. The clamps sound good not to crush them.
http://www.pelicanparts.com/techarticles/9...return_tube.htm Bob |
Lo-Fi Version | Time is now: 8th June 2024 - 02:50 AM |
