> pesky oil leaks..., loose head bolts??
crash914
post Mar 19 2007, 07:18 PM
its a mystery to me
ok, so I started to pull apart the motor to replace the base shims..
where is all this oil coming from?
my head nuts were loose, I think the oil was coming from the head stud to the case?
anyone else run across this?Attached Image
it looks like my cylinder was leaking also...
Replies(1 - 12)
crash914
post Mar 19 2007, 07:21 PM
its a mystery to me
ARP studs,
finger tight in case, I think I forgot to use sealant on them..
cylinder base shim looks good, no leaks,
oil pump looks good, no leaks,
galley plugs look good, no leaks..
I am running a little rich though... (IMG:style_emoticons/default/dry.gif)
crash914
post Mar 19 2007, 07:24 PM
its a mystery to me
head shot...
Pat Garvey
post Mar 19 2007, 08:09 PM
Do I or don't I...........?
Did you torque the heads in the proper sequence?
I didn't & have cylinder head oil leak after 20 years ( minor, but major on a CW car). Took a shortcut - got burned.
It DOES leak. It DOES make a mess. I AM stupid. I WILL fix it this spring.
DUMB, DUMB, DUMB. Got expert advice. Didn't listen. Paying for it now.
Anyone know if you can change this seal/gasket without removing the motor?
Apologize for hijacking this thread.
Pat
crash914
post Mar 20 2007, 11:34 AM
its a mystery to me
bump.... (IMG:style_emoticons/default/icon_bump.gif)
Matt Romanowski
post Mar 20 2007, 01:20 PM
Herb, It can also be a leak somewhere about and just leave the trail there due the movement on of the air. Found my oil leak last year - the top of a valve cover! Make sure your's are flat.
crash914
post Mar 20 2007, 04:34 PM
its a mystery to me
Matt, mine are flat, I also welded in a support to the gasket on the inside...remember my trail at NHIS??
I for sure had a cylinder to head leak, I am thinking that due to this I might also have been leaking out of the head stud to case area.
It might be hard to see in the pictures..thanks,
McMark
post Mar 20 2007, 04:39 PM
914 Freak!
Welding can cause warping in the valve covers.
Pat: Save the headache and remove the motor. You have to pull all the injection/tin off, not to mention that I doubt you could remove a head with the engine in the car. Don't solve a shortcut with a shortcut. (IMG:style_emoticons/default/tongue.gif)
crash914
post Mar 20 2007, 06:05 PM
its a mystery to me
mark, motor is already out....
I did talk to Charles about the torque...
he did mention doing a re-torque. I guess I never did that...
I also cc'd the heads...does 80cc seem right???
look in the picture above..pretty deep cuts and port work...very large valves...
Brando
post Mar 20 2007, 08:05 PM
BUY MY SPARE KIDNEY!!!
80cc per chamber doesn't sound right. Sure it's not 40 and 40?
Check your rings. I've taken apart a few engines (not alot, i'm still a noob) that showed leaks similar to yours that had broken rings.
Aaron Cox
post Mar 20 2007, 08:10 PM
Professional Lawn Dart
you cc'd to the bottom of the head?
you only measure to the lip where the cyl sits
crash914
post Mar 21 2007, 05:20 AM
its a mystery to me
cylinders are coming off to replace base shims...
cc yes to the bottom of the relief...80cc's I need to verify,
this is a 103 motor, but this drops my CR to around 7 or 7.5....no good...
Allan
post Mar 21 2007, 08:39 AM
Teenerless Weenie
I don't know if I'm comparing apples to oranges here, but my /6 leaked from between the cylinder and case when the head was loose.
- Lo-Fi Version Time is now: 3rd July 2025 - 02:09 AM
