1.7 pulley seal leak |
MiddleGACruiser |
Mar 22 2007, 07:35 PM
Hobbits? What Hobbits? Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None |
I replaced my pulley seal but it appears to still leak. Is there a sleeve available for the impeller hub or is the hub a common item which sometimes needs replacement?
Cap'n Krusty |
Mar 22 2007, 08:31 PM
I've seen a couple of grooved hubs that were beyond use, but it's not a common problem. You have adequate breathing for the crankcase? Did you change the o-ring, too? The Cap'n
Al Meredith |
Mar 22 2007, 08:39 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
The last post was right, There is an O ring behind the hub. You will probably have to use a puller the get the center hub off the crank. This O ring is often left off or not changed during a rebuild.
Lo-Fi Version | Time is now: 7th June 2024 - 08:57 PM |
