| drewvw |
Mar 27 2007, 03:11 PM
new england car guy ![]() ![]() ![]() Group: Members Posts: 1,632 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
OK...in the spirit of SQL questions being answered the last couple days, i have one that i could REALLY USE SOME HELP WITH.
I am about to tear my hair out here. In a basic explanation, we are trying to setup a test environment for an application I am building. There are some existing Stored Procedures and they reference a linked server to do some of the work. For Example: the stored procs reference dbname.dbo.table where "dbname" is a linked server. For the test environment, we want to create a linked server by the same name, only it points to the test db on another server "testname" that is exactly the same as production. So do avoid having to change all the names in the stored proc The problem is we get all kinds of DTC errors depending on what options we try, but they are basically all like "cannot find 'dbname' in syslinks" or "cannot start Distributed Transaction." its driving me crazy...can anybody give me a link or a step by step on how to do what i am describing above. PLEASE... drew |
| blitZ |
Mar 27 2007, 03:32 PM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
You can always create a vew, which selects a linked table. This would be helpful transitioning from development to production environments. Create the view with same name in both environments which point to the corresponding linked table, dev or prod. In SQL 7 and later, you can do inserts, updates and selects on views.
CREATE VIEW viewName AS Select * from linkedtabe |
| SirAndy |
Mar 27 2007, 03:41 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,533 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
can anybody give me a link or a step by step on how to do what i am describing above. sounds more like a DNS/network issue ... is the target server is available on the network under the same name as used in the SP? is your dev network connected to the live network? if so, you need to make sure that your SQL setup points to the correct linked SQL server ... can you access the linked server directly using a ODBC DSN? (IMG:style_emoticons/default/idea.gif) Andy |
| drewvw |
Mar 27 2007, 03:42 PM
You can always create a vew, which selects a linked table. This would be helpful transitioning from development to production environments. Create the view with same name in both environments which point to the corresponding linked table, dev or prod. In SQL 7 and later, you can do inserts, updates and selects on views. CREATE VIEW viewName AS Select * from linkedtabe right....but that doesn't help in this case because essentially the SPs are already referencing views in many cases, which do just what suggested. |
| drewvw |
Mar 27 2007, 03:47 PM
is the target server is available on the network under the same name as used in the SP? yes it is, however no links in the test db reference it is your dev network connected to the live network? if so, you need to make sure that your SQL setup points to the correct linked SQL server ... can you access the linked server directly using a ODBC DSN? I will pass that on to the DBA, but we are able to access tables via Query Analyzer. local statements work fine too...its just when you try to ref the Linked Server i appreciate the input from everyone, today has sucked. |
| SirAndy |
Mar 27 2007, 03:58 PM
does the linked server run on a non-standard port? (IMG:style_emoticons/default/idea.gif)
i *always* use a port other than 1433 for production SQL servers, even if they're not in the open and firewalled. if so, it could be that it's missing a setting and tries to access it through the standard port ... just blurting out stuff ... (IMG:style_emoticons/default/biggrin.gif) Andy |
| sjhowitson |
Mar 27 2007, 04:19 PM
Member ![]() ![]() Group: Members Posts: 478 Joined: 4-August 04 From: Moraga, CA Member No.: 2,449 |
| drewvw |
Mar 27 2007, 08:08 PM
I'm back..sorry fighting a cold i had to rest for a bit. i appreciate the blurting im sending along everything you guys are saying to the DBA. I am going to try a couple more things ill get back to you. |
Lo-Fi Version | Time is now: 10th October 2026 - 04:36 AM |
