2056 build, got some parts from the machine shop |
DanT |
Apr 7 2007, 11:34 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
OK after about 2 months at the machine shop, I finally got my bottom end back.
Case line bored, galley plugs tapped and plugged, decked. crank, balanced and polished Pressure plate balanced Flywheel, balanced and lightened to ~13#s Mahle cylinders bored and honed to 96mm KB flat top pistons matched to cylinders and rebalanced Rods, balanced, check for roundness at both ends, new small end bushings and new rod bolts. Reassembly will begin next week once I get the new rod bearings... Heads will be completed on Monday with new guides, seats, SS valves, exhaust studs (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif) Attached image(s) |
Aaron Cox |
Apr 7 2007, 11:37 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
nice! im right behind you doin the top end on my 2.0.
how much did the heads get decked? any idea of their volume? nice work - what did it cost ya? |
DanT |
Apr 7 2007, 11:44 PM
nice! im right behind you doin the top end on my 2.0. how much did the heads get decked? any idea of their volume? nice work - what did it cost ya? Aaron, I will get the total costs on Monday when I pick up the heads. I should have the other information as well. Volume and other specifics will be available after I pick them up. I am not going to run high CR, probably around 8.5 or 8.6. Due to points considerations with our rules. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:45 AM |
