| yarin |
Apr 15 2007, 07:47 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Can you replace the factory head temp sensor with the engine still in the car?
Thanks |
| ejm |
Apr 15 2007, 07:57 AM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It can be done. There are special sockets made for this that have a slot for the wire. I use a deep six point socket that has the face ground flush so it grabs as much of the sensor as possible. To clear the wire use an extension that has one corner ground off. Thread the wire up thru the socket then put the extension in.
| TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes. 13mm very deep socket. grind one corner off a short extension for the wire to pass thru.
| yarin |
Apr 15 2007, 08:18 AM
I assume I have to remove that side of the engine tin?
| BMartin914 |
Apr 15 2007, 08:23 AM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
| yarin |
Apr 15 2007, 08:36 AM
Ok.. I didn't realize there was an access hole for the sensor. Looks like its an easy job. Just have to remove the intake runners.
Thx |
| BMartin914 |
Apr 15 2007, 08:50 AM
You don't even have to remove the intake runners (that can be a PITA), just work around them. I've done it many times before...
| rmital |
Apr 15 2007, 09:59 AM
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,955 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Most IMPORTANT....put just a couple drops of super glue on the copper washer and attach to the sensor so you don't drop it down into the engine tin.
slot for wire...worked like a charm.... Attached image(s)
| Tobra |
Apr 15 2007, 10:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
so I am guessing you have one copper washer in there since you say it like that
| rmital |
Apr 15 2007, 10:11 AM
so I am guessing you have one copper washer in there since you say it like that nah...just glad someone else point that out before I changed mine. Made sure I had some glue on hand for the job. Not a typical item in the tool box. Don't know how else you'd get it on there (with the washer) with the engine in the car... |
| Bleyseng |
Apr 15 2007, 10:17 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes. 13mm very deep socket. grind one corner off a short extension for the wire to pass thru. yep, this is what I use. (IMG:style_emoticons/default/agree.gif) |
| NoEcm |
Apr 16 2007, 01:10 AM
Member ![]() ![]() Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 |
This works too (circa 1981 or 1982):
Attached thumbnail(s) |
| Jeffs9146 |
Apr 16 2007, 05:41 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Be careful not to cross thread the sensor threads. The PO did this on my motor and it would intermitantly loose contact and mess up the mixture. I had to tap and coil new threads in to make it work! PITA
| pbanders |
Apr 16 2007, 06:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
so I am guessing you have one copper washer in there since you say it like that nah...just glad someone else point that out before I changed mine. Made sure I had some glue on hand for the job. Not a typical item in the tool box. Don't know how else you'd get it on there (with the washer) with the engine in the car... I'll take credit for that tip, I think I'm the source (IMG:style_emoticons/default/smile.gif) The copper washer is important for good heat transfer from the head to the sensor. Hard to understand why they didn't make it captive, considering how it's installed. BTW, in another thread, I reported that for VW applications, there is a spacer that you can put between the CHT and the head. It's about 3/4" long. The idea is that it delays the sensor from being heated up initially when the motor is cold, so that the mixture stays richer for a longer time. Might be an interesting way to fix some warm-up issues. |
Lo-Fi Version | Time is now: 14th August 2026 - 11:47 AM |
