What sealant should I use between oil pump and case |
mike373 |
Apr 27 2007, 02:55 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
Should I use Curil K2....or loctite 565??? Also what can be used to keep the windage tray gaskets on??
Thanks, Mike |
G e o r g e |
Apr 27 2007, 03:14 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
loctite 565 on case , then gasket then k2 on face of pump
curil k2 between cover - gasket/ gasket - pump if using type 1 pump no windage tray here, sorry |
Lo-Fi Version | Time is now: 11th June 2024 - 04:01 AM |
