Pedal cluster, clutch spring push pedal up or down? |
eric914 |
Apr 28 2007, 09:28 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I got my motor in last night and began hooking the cables up. The clutch cable seems to be spring biased to the engagement position. I went to look at the cluster and the clutch pedal is spring loaded to the down position. Is this correct?
(Photo Stolen From another Thread) Attached image(s) |
Eric_Shea |
Apr 28 2007, 09:35 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Down as shown in the photo.
eric914 |
Apr 28 2007, 09:51 AM
Does this then pull the clutch cable so that the through out bearing is constant contact with the pressure plate.
Just seems odd. It's been 4 years since I took apart the last car and I have never driven a 914. Hopefully that will change this weekend. (IMG:style_emoticons/default/smile.gif) |
Dave_Darling |
Apr 28 2007, 12:08 PM
Yes, that's the way it works. That's one reason that checking the free play on your clutch means pulling up on the pedal--the spring pulls it down.
--DD |
Lo-Fi Version | Time is now: 11th June 2024 - 10:57 AM |
