geniusanthony |
Its a brand new "Chrome-sicle" ![]() ![]() ![]() Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region ![]() |
my left rear caliper is slowwww to release, also when attempting to bleed almost no fluid wants to come out, I though maybe a collapsed line but could it be the caliper itself, btw. rear calipers are 914-4 front calipers...911 M's in front.
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
There are not that many moving parts in a calliper and fluid moves the piston. If you take it apart, first get a rebuild kit and might as well do both, you will most likely see some corrosion on the side of the piston whic impedes it's movement unless the tolerence is huge. Happened to me once on a bike front calliper which squeeled like a stuck pig. (IMG:style_emoticons/default/beer.gif)
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,290 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
collapsed line is most likely
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,829 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
How old are the flex lines? If they are old they can internally swell and act like a check valve.
Lo-Fi Version | Time is now: 9th July 2025 - 11:56 AM |
