broken gas guage and odometer, what is best spare gas can ?? |
jimkelly |
May 1 2007, 08:00 AM
for the meanwhile - versus plastic can for getting lawnmower gas ??
jim |
root |
May 1 2007, 01:54 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
for the meanwhile - versus plastic can for getting lawnmower gas ?? jim I started feeling bad for you, 'cause nobody responded to your goofy post so here you go..... Safety Can Man (IMG:style_emoticons/default/chair.gif) Mcmaster Carr cat# 4290T5 - color choices - Blue, Red, Yellow less than 30 bucks (IMG:style_emoticons/default/beerchug.gif) |
root |
May 1 2007, 01:56 PM
for the meanwhile - versus plastic can for getting lawnmower gas ?? jim I started feeling bad for you, 'cause nobody responded to your goofy post so here you go..... Safety Can Man (IMG:style_emoticons/default/chair.gif) Mcmaster Carr cat# 4290T5 - color choices - Blue, Red, Yellow less than 30 bucks (IMG:style_emoticons/default/beerchug.gif) like this! Attached image(s) |
jimkelly |
May 1 2007, 02:38 PM
i will check for optional sizes - that one may be too tall but looks robust enough for a 914 : )
i guess front truck best for gas can - back truck may be KA BOOM prone : ( jim |
azbill |
May 1 2007, 02:54 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
It is a simple fix - fix the gas gauage, an odometer is nice but really needed. (IMG:style_emoticons/default/biggrin.gif)
toon1 |
May 1 2007, 02:59 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Fill up every day! (IMG:style_emoticons/default/biggrin.gif) tha odo is not that hard to fix
jimkelly |
May 1 2007, 03:03 PM
http://www.pelicanparts.com/techarticles/9...der_replace.htm
It is a simple fix - fix the gas gauage, an odometer is nice but really needed. (IMG:style_emoticons/default/biggrin.gif) |
markb |
May 1 2007, 03:36 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Fix the problems. Odo is not that hard. Gauge is probably just a stuck sender. Take it out & clean it. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:59 PM |
