DrifterJay |
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None ![]() |
all I need to say is that this 914 is frustrating, and more than one person will agree with me...lol
damn I just want to drive... (IMG:style_emoticons/default/driving-girl.gif) one day (IMG:style_emoticons/default/wub.gif) |
Rich Bontempi |
914 Road Racer ![]() ![]() Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California ![]() |
What has you frustrated? (IMG:style_emoticons/default/icon14.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Everything is only hard the first time. (IMG:style_emoticons/default/biggrin.gif)
Keep fighting the good fight. At least you have a massive support group here to help out. Yay, 914 Club. |
DrifterJay |
oh so true....two extremely helpful members came by today and had two other offers...but my motor is cursed to never start....ever...
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
Well I dont know what too say about this car. my son spent 3 hrs checking the valves, the timing, the points, and the fuel pump. we got spark at the plug. the car farted once or twice but would not start. had Jared get new plugs and starting fluid but it didn't help. we tried
Bernie (IMG:style_emoticons/default/confused24.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,008 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
What is it not doing, spark, fuel, what?
DrifterJay |
You did indeed...thank you guys a lot, that was a good experience, just goes to show that this site truly is a community. (IMG:style_emoticons/default/smile.gif)
Jared |
DrifterJay |
it has spark, it has fuel, it has compression, wont turn over...one last thing is possibly a new starter...but it would fire up just fine before dropping the motor...so what gives???? (IMG:style_emoticons/default/blink.gif)
DrifterJay |
(IMG:style_emoticons/default/wink.gif) I should just bolt in a Briggs and Stratton...more power
Rich Bontempi |
Check the ground strap from the trans to the body, It needs to be clean and tight for the starter to have a good enough ground to crank correctly. Or the starter could have taken a dump! What else did you touch?
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
QUOTE(markd@mac.com @ Dec 6 2003, 10:18 PM) Everything is only hard the first time. (IMG:style_emoticons/default/biggrin.gif) Keep fighting the good fight. At least you have a massive support group here to help out. Yay, 914 Club. That is so true. The second time I touch anything on the car it is much easier. I'm definately getting better at wrenching. :-). (IMG:style_emoticons/default/clap56.gif) |
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
What did you do to it again that you had to drop the motor?
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
It had a stuck valve, among other problems. Hmm... a weak starter will turn over a shitty motor.... hmm.. (IMG:style_emoticons/default/idea.gif)
Push start? M |
McMark |
If the starter is turning the engine but sounds like it has a half dead battery then you might have the spark plug wires one hole off. Did you turn the case over at all? The distributor drive could have fallen out and then fallen back in at the wrong orientation. Check that when cylinder 1 is on TDC of the compression stroke the rotor is pointed towards the drivers seat (roughly) and set the vacuum canister to be aimed at the oil filler box (roughly). This should get your timing in range. Make sure the post inside the distributor cap that the rotor is pointing at is the one for cylinder 1 and then set all the wires from there (1-4-3-2 clockwise). This all sounds very much like a timing issue to me. If I get a chance after work I'll take some pictures.
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Hmmmmmmmmmmm,
My brother is looking for a project.....gimme money for mine..."IT" runs and I'll see what I can do with baby bro.... |
DrifterJay |
hmm tempting...if you still have it in a month, I can allocate the proper funds...
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
DrifterJay,
Describe what you did. We can get it started I am sure.... 1) Did you remove the distributor? 2) Did you remove the starter 3) did you remove the wiring and recconect it all, including the plug into the relay panel behind the driver in the engine bay?? 4) Did you rebuild the motor? 5) have you checked the firing order??? (s stated above, it will turn, but slower if the plug wires are not correct, but it will not start and could make the starter sound like a pig) details will help you solve this.... If fuel injected, put the key in the run position, you should hear the fuel pump pre-charge the FI system....a slight wirring should occur and should stop ,,,,about two seconds. Make sure all your wiring and grounds are connected for the FI system, and are not on the wrond injectors. Make sure your plug to the pressure sensor, injectors, injector point (on dissy) are connected |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Jay, Rich is right. This problem can be solved. If it ran when you removed the motor, and you hooked everything back up correctly, it should run. We have to know exactly what you did to the car.
How did you "unstick" the valve? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
he put new heads on
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Drifter Jay,
Dunnow if your engine turns over easily. How did you torque the heads? If you do it wrong, you can oval the case at the crank bearings and and cause a bind or extra drag. Bought a car from a PO cuz he decided to take his engine out and replace the heads with 2 new ones to fix a valve problem. He got it torqued back together and back into the car only to find it won't turn over. I got (at a minimum) 2 virgin 2.0l heads that way for $300. Need any free rust? (IMG:style_emoticons/default/laugh.gif). Hope this helps! Ken |
Lo-Fi Version | Time is now: 1st July 2025 - 03:02 AM |
