Vacuum hose junction, Special part? |
whitey |
May 14 2007, 01:34 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
Is the vacuum hose junction for the 12mm hose anything special (ie, check valve, etc.) or just an open "y" for connecting the hose...I need one...
Thanks, Dave |
Dr Evil |
May 14 2007, 08:53 AM
Just a Y
Dave_Darling |
May 14 2007, 09:10 AM
Which 12mm hose? There's one that is nestled up in the fan shroud that has a screen in it to act as a spark arrestor.
The others are, AFAIK, all simple junctions. --DD |
whitey |
May 16 2007, 12:43 AM
Thanks for the input...I figured it out.
Dave |
DanT |
May 16 2007, 12:46 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
are you talking about this one? Lower right corner?
It is called the anti flashback valve.....I think it is more than a simple Y connection? (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
914Sixer |
May 16 2007, 08:23 AM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a used Y for Free if you need one. Send me your address and I will get it off to you.
Dave_Darling |
May 16 2007, 09:55 AM
Lo-Fi Version | Time is now: 28th May 2024 - 05:23 PM |
