injectors on passenger side not firing |
buck toenges |
May 14 2007, 11:50 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
'72 1.7 new rebuilt injectors. Can't get them to fire. Funny thing is that they are both on the passenger side of engine. Bad grounds from the fuel injection harness? I think the trigger points in the distributor fire the injectors on the cylinders catacorner to each other don't they?
What to do? What to check? Thanks, Buck |
tdgray |
May 14 2007, 12:42 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Check your trigger points... sounds like a bad set.
IIRC TP's fire each side. Also... check your harness connections and the TPS. |
Bleyseng |
May 14 2007, 12:50 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
check the grounding block
rmital |
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
injectors on one side out = bad grounds
injectors (1&4) or (2&3) out = bad trigger points |
Dr Evil |
May 14 2007, 01:04 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
injectors on one side out = bad grounds injectors (1&4) or (2&3) out = bad trigger points Look at Ray with the knowledge (IMG:style_emoticons/default/thumb3d.gif) (Except 1&3, 2&4) |
tdgray |
May 14 2007, 01:20 PM
Thanks for correcting me boys... obviously I did not recall correctly.
Cap'n Krusty |
May 14 2007, 03:09 PM
Check your trigger points... sounds like a bad set. IIRC TP's fire each side. Also... check your harness connections and the TPS. Pardon me, but you're WRONG. The trigger points fire 1/3 and 2/4, which are pairs of injectors on OPPOSITE sides of the engine. The TPS has no bearing on the question. The most likely culprit here is the ground connections under the intake plenum. The Cap'n |
Dr Evil |
May 14 2007, 03:11 PM
Wow, polite AND answered the question that no one had answered yet (IMG:style_emoticons/default/dry.gif)
rmital |
May 14 2007, 03:53 PM
injectors on one side out = bad grounds injectors (1&4) or (2&3) out = bad trigger points Look at Ray with the knowledge (IMG:style_emoticons/default/thumb3d.gif) (Except 1&3, 2&4) oops....I'm getting closer. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:28 PM |
