Will it ever end? Not looking good! |
customstarr |
Jun 19 2007, 06:09 PM
King of the Nighttime World Group: Members Posts: 116 Joined: 13-February 07 From: Waterford, Michigan - Home of Waterford Hills Road Racing Member No.: 7,531 |
My car still idles like pure crap. Very inconsistent - high to low surging, super low, rich... you name it, this car's idle is ALL OVER THE PLACE. It's never the same condition. The car runs like a raped ape and goes good, but the idle sux complete ass. I used to be able to get some idle adjustment at the TB screw (I don't have the ECM screw), but today I set the fuel pressure correctly (was at 42 PSI) and now I have no control over the idle mix/speed. Maybe someone in the past tried to cover the problem by cranking up the fuel pressure. I'm not seeing the super rich condition now, but like I said... no control.
I've been through everything: replaced/fixed wiring, new ignition system, battery, cables, checked all the standard fare + what I've listed below, etc. This is getting ridiculous. What I've replaced thus far: 1. Ignition: Coil, Cap, Rotor, Points, Condenser, Plugs, Wires (all Bosch except plugs). 2. Fuel/D-Jet: TS1, Fuel Filter, Vacuum Lines. What I've checked, adjusted to spec, or tested to be good: 1. Ignition: Points, Timing, Trigger Points. 2. Fuel/D-Jet: MPS, TS2, Fuel Pressure Reg, Cold Start Valve, Aux Air Reg, Injectors, Fuel Lines, Fuel Pump, Throttle Body, Throttle Switch. 3. Engine: Timing, Compression, Valves. |
scotty b |
Jun 19 2007, 06:16 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
There is a 3 way rubber "Y" underneath the intake box that I had to replace on my dads car several years ago. That alone was causing all of his erratic idleing.It cannot be seen with the intake bolted on. Looking at the engine from the fan housing end, it is to the right of center and just behind the fan housing. I"ll see if I can get to his engine to take a pic of it.
scotty b |
Jun 19 2007, 06:28 PM
Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about.
rjames |
Jun 19 2007, 06:49 PM
I'm made of metal Group: Members Posts: 3,974 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Did you replace the injector seals? Mine was idling up and down after it warmed up until I replaced the seals.
Johny Blackstain |
Jun 19 2007, 06:50 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about. Scotty- does this help? 74 D-jet w/ air filter removed- (IMG:style_emoticons/default/cool_shades.gif) Attached image(s) |
scotty b |
Jun 19 2007, 06:56 PM
[quote name='Johny Blackstain' date='Jun 19 2007, 04:50 PM' post='913326']
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Jun 19 2007, 08:28 PM) </div><div class='quotemain'><!--quotec--> Nope I can't get to the engine for all of the sh*t I have piled up. Maybe somebody else will know what I am talking about. [/quote] Scotty- does this help? 74 D-jet w/ air filter removed- (IMG:style_emoticons/default/cool_shades.gif) [/quote] Kionda. It's right there under the #1 runner where the 3 hoses seem to intersect. All I remember is there is also a small steel body with 2 ports down there also that the "Y" connects in with. See the green hoses from the intake boot and the air filter? That is the metal part and the rubber piece is there as well. Somebody will know it (IMG:style_emoticons/default/headbang.gif) Attached image(s) |
ConeDodger |
Jun 19 2007, 06:57 PM
Apex killer! Group: Members Posts: 23,623 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
My car still idles like pure crap. Very inconsistent - high to low surging, super low, rich... you name it, this car's idle is ALL OVER THE PLACE. It's never the same condition. The car runs like a raped ape and goes good, but the idle sux complete ass. I used to be able to get some idle adjustment at the TB screw (I don't have the ECM screw), but today I set the fuel pressure correctly (was at 42 PSI) and now I have no control over the idle mix/speed. Maybe someone in the past tried to cover the problem by cranking up the fuel pressure. I'm not seeing the super rich condition now, but like I said... no control. I've been through everything: replaced/fixed wiring, new ignition system, battery, cables, checked all the standard fare + what I've listed below, etc. This is getting ridiculous. What I've replaced thus far: 1. Ignition: Coil, Cap, Rotor, Points, Condenser, Plugs, Wires (all Bosch except plugs). 2. Fuel/D-Jet: TS1, Fuel Filter, Vacuum Lines. What I've checked, adjusted to spec, or tested to be good: 1. Ignition: Points, Timing, Trigger Points. 2. Fuel/D-Jet: MPS, TS2, Fuel Pressure Reg, Cold Start Valve, Aux Air Reg, Injectors, Fuel Lines, Fuel Pump, Throttle Body, Throttle Switch. 3. Engine: Timing, Compression, Valves. Check your plenum to runner tubes for leakage. Pull your plenum off and shine a light inside it and look for the light to come through from the outside. These things can be sneaky but it sounds like a vacuum leak and EFI hates vacuum leaks. |
Johny Blackstain |
Jun 19 2007, 07:00 PM
Scotty- D-jet changed over the years... my charcoal canister is mounted on the backside of the rear trunk wall, inside the engine bay. Here's another top shot-
scotty b |
Jun 19 2007, 07:06 PM
If this hasn't been resolved by Saturday I'll dig my way to the engine and get a pick of the piece. I need to get rid of some sh.....parts (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
customstarr |
Jun 19 2007, 08:12 PM
My car is plumbed exactly like the diagram. Intake boot to Aux Air Valve, Air filter to Oil Breather, Throttle body to distributor x 2, Intake to MPS, and AIr Cleaner to Canister. I'm not aware of any "Y" connectors, or any additional hoses. This is a 1971 D-Jet just for clarification.
I'll look for more vac leaks, but I'm not aware of any at the intake. |
BahnBrenner914 |
Jun 20 2007, 12:30 AM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
I'll look for more vac leaks, but I'm not aware of any at the intake. Have you tried the "propane vacuum leak finding method"? Some of the guys in here advocate it. you take a small propane torch and turn it on (not lit) and probe around with it while the teener is running. Then the vacuum leak will suck it in and change speed (higher?lower, I think I heard both). |
customstarr |
Jun 20 2007, 08:01 AM
I'll look for more vac leaks, but I'm not aware of any at the intake. Have you tried the "propane vacuum leak finding method"? Some of the guys in here advocate it. you take a small propane torch and turn it on (not lit) and probe around with it while the teener is running. Then the vacuum leak will suck it in and change speed (higher?lower, I think I heard both). That's a great idea, but the idle is so unstable and erratic that it would be hard to note any change in idle speed. |
Twise |
Jun 20 2007, 10:59 AM
Member Group: Members Posts: 475 Joined: 20-September 06 From: SoCal - Temecula Member No.: 6,881 Region Association: Southern California |
I had this problem with my 1.8 litre - I was told by Martin Christensen at All German Auto that a part (a valve) was no longer available that would get the idle back into whack. My car would not idle until it got real warm, and sometimes not even then. You could call Martin or Auto Atlanta - This is a well known problem, or that is what I was led to believe. 760-739-4626 or http://www.allgermanauto.com/index.php
Good Luck... |
customstarr |
Jun 20 2007, 02:44 PM
I had this problem with my 1.8 litre - I was told by Martin Christensen at All German Auto that a part (a valve) was no longer available that would get the idle back into whack. My car would not idle until it got real warm, and sometimes not even then. You could call Martin or Auto Atlanta - This is a well known problem, or that is what I was led to believe. 760-739-4626 or http://www.allgermanauto.com/index.php Good Luck... Thanks for the info. Not aware of a valve, but i'll look into it. |
Bartlett 914 |
Jun 20 2007, 03:14 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I had this problem with my 1.8 litre - I was told by Martin Christensen at All German Auto that a part (a valve) was no longer available that would get the idle back into whack. My car would not idle until it got real warm, and sometimes not even then. You could call Martin or Auto Atlanta - This is a well known problem, or that is what I was led to believe. 760-739-4626 or http://www.allgermanauto.com/index.php Good Luck... Thanks for the info. Not aware of a valve, but i'll look into it. I had leaks in my intake plenum. This can also cause Idle problems. TS2, is this the CHT (cylinder head temperature sensor). The CHT is on the head near cylinder 3. Did you check this?. If not, a pot can be substituted as a testing device. Should be a low value when warm. 100 to 200 ohms IIRC. There is a difference in these between 73 and 74. Maybe it is intermittent or loose. Also make sure that the engine ground connection is good. There are also ground connectors on the top of the motor. Make sure all is clean and tight. Lots of luck |
SirAndy |
Jun 20 2007, 03:21 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
dr914@autoatlanta.com |
Jun 20 2007, 03:44 PM
914 Guru Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
My car is plumbed exactly like the diagram. Intake boot to Aux Air Valve, Air filter to Oil Breather, Throttle body to distributor x 2, Intake to MPS, and AIr Cleaner to Canister. I'm not aware of any "Y" connectors, or any additional hoses. This is a 1971 D-Jet just for clarification. I'll look for more vac leaks, but I'm not aware of any at the intake. your car (71) is prone to lean idle (high low idle) as the control unit is not adjustible in the early cars (no knob) and with old injectors and vacuum leaks (make sure that the aux air valve is closing by removing the hose to the u shaped intake boot and making sure that it is not sucking vacuum) When this is verified you can then as the car hi low idles spray carb cleaner around all of the fittings to see if the idle changes. If to no avail, and you have carefully checked everything you said (including proper routing of all of the vacuum lines and ascertained that the vacuum advance/retard is working properly, and remember that AUX AIR VALVE to make sure it is closing when the engine is hot) for the hell of it, install an inline 270 ohm resistor with the head temp sensor to richen the idle mixture and see what happens. |
customstarr |
Jun 21 2007, 06:55 AM
My car is plumbed exactly like the diagram. Intake boot to Aux Air Valve, Air filter to Oil Breather, Throttle body to distributor x 2, Intake to MPS, and AIr Cleaner to Canister. I'm not aware of any "Y" connectors, or any additional hoses. This is a 1971 D-Jet just for clarification. I'll look for more vac leaks, but I'm not aware of any at the intake. your car (71) is prone to lean idle (high low idle) as the control unit is not adjustible in the early cars (no knob) and with old injectors and vacuum leaks (make sure that the aux air valve is closing by removing the hose to the u shaped intake boot and making sure that it is not sucking vacuum) When this is verified you can then as the car hi low idles spray carb cleaner around all of the fittings to see if the idle changes. If to no avail, and you have carefully checked everything you said (including proper routing of all of the vacuum lines and ascertained that the vacuum advance/retard is working properly, and remember that AUX AIR VALVE to make sure it is closing when the engine is hot) for the hell of it, install an inline 270 ohm resistor with the head temp sensor to richen the idle mixture and see what happens. Thanks for the input George, I could really use some help with this - I'm seriously about reading to chalk this up as a loss. I wish the car had a lean condition causing the poor idle, but that's not the case. This car runs so rich it will gag you. It is however, very unstable idle wise. Recently I checked and adjusted the Fuel Pressure - it was at 42 PSI and I set it to 30 PSI. I expected the car to run better, and that wasn't the case. Suddenly, I lost control over idle adjustment via the TB screw - it always worked in the past, but once I corrected the fuel pressure, the screw stopped having ANY effect on idle (accept for choking it off when screw all the way in). I've adjusted valves, set timing, new ignition system, you name it... I was thinking a leaky Cold Start Valve, but I bypassed that with no improvement. I guess it's hard to tell through, because my 3rd set of plugs are fouled - that's not helping my cause now. |
Johny Blackstain |
Jun 21 2007, 07:02 AM
I noticed nothing mentioned about your return line in this thread. Have you checked the fuel return? Does your 71 D-jet have a fuel return like my 74 (IMG:style_emoticons/default/blink.gif) ? If it's clogged that could be the source of your irratic idle? Don't give up on her yet & good luck!
(IMG:style_emoticons/default/cool_shades.gif) |
Bartlett 914 |
Jun 21 2007, 07:18 AM
You may also have a bad electrical connection to the ECU. Wires get old and crack. Dirt also plays havoc on connections. Make sure the connector on the ECU hac clean connections. Also make sure that there is a connection from the CHT (near cyl #3) to the ECU. This connection could be broken.
Don't give up! There is an answer and you will find it. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:16 AM |
