> Good Deal on Evilbay?, Pistons and cylinders - Mahle's
tracks914
post Dec 13 2003, 10:30 AM
Canadian Member
Pistons and Cylinders
I believe these are for a 2.0 L. Would they be of any use to someone rebuilding a 1.7?
Price looks good but whats the catch?
Tx
Doug
Replies(1 - 19)
Katmanken
post Dec 13 2003, 10:58 AM
You haven't seen me if anybody asks...
Go over to Shop Talk Foums and do a search on "West Coast Core".
Not sure if they are all "Mahle" parts.
Ken
Mark Henry
post Dec 13 2003, 11:03 AM
that's what I do!
It will give you the wrong deck height. You would also have to open up the head bores.
You would need a 2.0L crank set to do it right.
What are you going to use carb or FI?
tracks914
post Dec 13 2003, 06:00 PM
Canadian Member
I have 2 - 1.7's. One is complete and siezed.(spark plug missing) The other was running well when I bought the car and tore it down. Currently it is on the engine stand, stripped, and ready to split the crankcase and take journal readings.
I want to keep one of my engines original to stay with the car. So far it is all still "original".
I'm just weighing out my options for the other engine. $229 for a complete set of cylinders, pistons and rings sounds pretty reasonable if I can make them work on one of my engines.
Redoing the heads is not a problem but will things like, will my 1.7 engine tin fit over the 2.0 cylinders?
What is the cc's of 2.0 heads vs 1.7 heads? Will they even fit on the 2.0 cylinders? Will it change the compression ratio to the point that I would have to run higher octane gas?
Since the stroke is different would I end up with a 1.9L?
Would a 1.9L work with the 1.7 FI or should it run carbs for a more variable set up?
I have done a fair bit of mix and matching with V8's 305 to 350 - 318 to 340 to 360 (great success) and such but never with German engines.
Sounds like a challenging project but I just don't want to waste my money.
tracks914
post Dec 13 2003, 06:07 PM
Canadian Member
The add states that pistons are dish topped. Optional flat tops.
Mine are domed topped.
What are original 2.0's and 1.8's?
Mark Henry
post Dec 13 2003, 06:23 PM
that's what I do!
You will have too much deck height and that means to low of a CR.
1.7 and 1.8 have 66mm cranks, 2.0 has a 71mm, that would give you a extra 6mm of deck, your going the wrong way.
If opening up the head is no problem then get the 1.8 pistons. Should work OK with the stock FI (but I could be wrong).
The stock (USA) 2.0 piston does have a dish, but it's nowhere near the huge dish bus pistons have. Those are a bus piston, not 914.
The tin will fit OK, all type 4 engines look the same on the outside, except for the 2.0 914 heads.
tracks914
post Dec 14 2003, 02:20 PM
Canadian Member
Can the 2.0 cylinders be machined down to a 66mm crank stroke? It would apear that they could be put in a lathe and have 8mm machined off one end without too much trouble.
Are 2.0L (914) pistons flat topped, dished or domed?
Anyone know the cc difference between the 3 types of heads?
DuckRyder
post Dec 14 2003, 02:28 PM
Avatars Mode: OFF because of the recalcitrant few.
2.0 US pistons are dished.
2.0 Euro pistons are flat tops.
Mark Henry
post Dec 14 2003, 02:36 PM
that's what I do!
Your going about it the wrong way. If you don't believe me, ask over on the STF.
Also is this the company selling these piston sets?
http://www.shoptalkforums.com/viewtopic.php?t=61326
Brad Roberts
post Dec 14 2003, 02:39 PM
914 Freak!
The Euro's have a 3cc dish (not flat)
I have a 2.0 crank I can sell you with rods for 150$
Forget the whole "machine them for a 66 crank"
If you want to do that.. buy a set of 96's for a 66mm crank and make a 1911.
B
tracks914
post Dec 14 2003, 02:46 PM
Canadian Member
QUOTE(Mark Henry @ Dec 14 2003, 12:36 PM)
I read the thread, thanks, I'l stay clear of that guy. (IMG:style_emoticons/default/chair.gif)
Those weren't exactly what I was looking for, I am mostly just trying to figure out what can be done with these engines.There seems to be enough people tinkering with them that I was wondering what combinations work and what ones don't.
(eg. a set of 305 FI heads put on an older 350 smogger engine with raise the compression ratio and increase performance to the tune of about 30 hp and 800 rpm, by then the smaller valves limit any more output)
Does any of this logic apply to the 914?
tracks914
post Dec 14 2003, 02:50 PM
Canadian Member
QUOTE(Brad Roberts @ Dec 14 2003, 12:39 PM)
Here is what I'm talking about (IMG:style_emoticons/default/smile.gif) options!!!
1.911 will it work with 1.7 FI or would I have to convert to carbs?
Brad Roberts
post Dec 14 2003, 02:55 PM
914 Freak!
It will work with the stock injection (I normally install 2.0 injectors)
We dont have over 1million Small Block Chevy combo's to choose from so the options are slim.
My favorite combo in the past was a 1911 engine with true 2.0 914 heads and a nice cam with .450 lift and carbs. The 2.0 heads really wake up a 1911 engine (or even a 1.8 for that fact). What you end up with is a short stroke large bore combo that likes to REV right now.
B
DuckRyder
post Dec 14 2003, 02:56 PM
QUOTE(Brad Roberts @ Dec 14 2003, 04:39 PM)
I stand corrected, after looking at mine I should have said:
2.0 Euro pistons are virtually flat tops. (IMG:style_emoticons/default/smile.gif) 3cc seems generous, but I am sure that is right.
Brad Roberts
post Dec 14 2003, 02:59 PM
914 Freak!
I wouldnt have corrected you ...but several companies do sell a 94mm true flat top with NO dish. I have had people in the past pull apart engines I built and call me up saying "you said these where flat tops".. I quickly stopped using the term. Educating people about the parts is key.
B
tracks914
post Dec 14 2003, 03:04 PM
Canadian Member
QUOTE(Brad Roberts @ Dec 14 2003, 12:55 PM)
Now this sounds like a fun project for my spare engine (IMG:style_emoticons/default/mueba.gif)
I'll have to get it apart to see what is salvagable so I can start looking for parts.
DuckRyder
post Dec 14 2003, 03:06 PM
Oh, it is fine, you are right they do have a dish and we should have the right info out there.
I did not realize they had a dish until you said that. (IMG:style_emoticons/default/pray.gif)
Brad Roberts
post Dec 14 2003, 03:08 PM
914 Freak!
Here is what I have used in the past:
66mm counter weighted crank (was 199.00 in the past)
2.0 heads with stock rebuild
96mm Pistons/Cylinders
European Racing "H grind" camshaft
2.0 heat exchangers or the late 1.8 heat exchangers.
Balance the entire assembly.
Dual 40mm Dells or tweaked factory injection.
Bursch header/muffler
B
tracks914
post Dec 14 2003, 03:14 PM
Canadian Member
Dyno that and it must bring you up close to the 95 - 100 hp range? What rpm does it rev to?
Brad Roberts
post Dec 14 2003, 03:17 PM
914 Freak!
It easily rev'd to 6k and had power to 6k and didnt poop out like a stock 2.0 at 5200rpm. I also used a HD spring on the valves.
It was at least 100hp to the rear wheels (compared to driving other 100RWHP cars)
B
- Lo-Fi Version Time is now: 20th September 2026 - 02:08 PM
