What is the inner cable size of a -6 clutch cable?, Or do you know the difference between 4 and -6? |
PRS914-6 |
Jul 8 2007, 11:11 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Just as it says. I'm trying to determine if the cable I have is a -6 or a 4 cyl version. I'm assuming the 4cyl is smaller in diameter but I have not seen the two side by side. Mine measures .120
The 911 clutch cables are monsters compared to these (but they don't have to go around a pulley) |
SirAndy |
Jul 8 2007, 11:34 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just as it says. I'm trying to determine if the cable I have is a -6 or a 4 cyl version. I'm assuming the 4cyl is smaller in diameter but I have not seen the two side by side. Mine measures .120 The 911 clutch cables are monsters compared to these (but they don't have to go around a pulley) the /6 cable does not have the white plastic sheeting over the cable. the cable is thicker and it wouldn't fit inside the tube if it had the sheeting ... (IMG:style_emoticons/default/bye1.gif) Andy |
PRS914-6 |
Jul 8 2007, 11:43 PM
Thanks Andy. It's a -6 then
Lo-Fi Version | Time is now: 10th June 2024 - 05:50 AM |
