Flywheel endplay adjustment..question. |
mike373 |
Jul 9 2007, 03:11 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
Can the flywheel endplay be adjusted and measured between the backside of the fan hub and the snout of the engine case....where front seel is? This would be done with feeler gauges.
Mike |
Demick |
Jul 9 2007, 03:43 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
I suppose it can be measured from there. But not adjusted, as adjustment is done with shims at the flywheel end.
mike373 |
Jul 9 2007, 04:28 PM
Yes... I am aware of the flywheel shims. Has anyone else measured from here?? Would it give an accurate reading from here?
Joe Owensby |
Jul 9 2007, 05:03 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
The end play is how much the drive shaft can actually move along its axis. Technically, it can be measured on either end if you can get good access to do so.
Al Meredith |
Jul 9 2007, 08:13 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Tough to measure with both oil seals in place.
mike373 |
Jul 9 2007, 08:27 PM
Only my front oil seal is in place. And it is slightly inset from being flush from the case, so only metal is exposed on that face.
Lo-Fi Version | Time is now: 6th June 2024 - 01:22 AM |
