| plymouth37 |
Jul 12 2007, 11:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
I have put my 914 on a major diet, have naturally gone overboard and decided to go with fiberglass lids. I would go to getty design with no hesitation but they do not offer a fiberglass hood without headlight cutouts. I saw that gt racing offers them but am unsure of their quality. So whose fiberglass non-cutout hood sucks the least? Can anybody comment on gt racing's quality? I want the best fitting part possible (bolt on), I HATE working with fiberglass!
Thanks, Dana. |
| neo914-6 |
Jul 12 2007, 11:48 AM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I have put my 914 on a major diet, have naturally gone overboard and decided to go with fiberglass lids. I would go to getty design with no hesitation but they do not offer a fiberglass hood without headlight cutouts. I saw that gt racing offers them but am unsure of their quality. So whose fiberglass non-cutout hood sucks the least? Can anybody comment on gt racing's quality? I want the best fitting part possible (bolt on), I HATE working with fiberglass! Thanks, Dana. Dana, I used Rennspeed Fiberglass. Peter 626-256-8878 Not bad quality but the edge had to be worked to match the cowl better and there were some areas needing filler skim coats particularly where the headlights doors were. They were reasonbly priced. AIR also has headlight delete. Where are you mounting your headlights? |
| por73914 |
Jul 12 2007, 11:58 AM
I don't know what the hell I am doing... ![]() ![]() Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 |
Peter at Rennspeed is great to deal with! (IMG:style_emoticons/default/bye1.gif)
| plymouth37 |
Jul 12 2007, 12:18 PM
Thanks for the help guys,
QUOTE Where are you mounting your headlights? I mounted KC hilites in the foglight holes, they do not have a high beam but are so much brighter than stock. They really work great and since I live in wyoming I really don't have to worry about getting busted for dot violations! Sorry for the crappy cell phone pic: ![]() |
| dr914@autoatlanta.com |
Jul 12 2007, 12:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we made one for the 9014 that works well and has the innerstructure made in fiberglass as well. Fit is very nice and sold for 450.00 but we make them as needed.
| plymouth37 |
Jul 12 2007, 12:33 PM
| plymouth37 |
Jul 12 2007, 01:25 PM
So I just found out that GT racing (http://www.gt-racing.com) is only a couple hours south of me which means I can just pick up a set of lids and not have to pay shipping (IMG:style_emoticons/default/piratenanner.gif)
BUT if their quality is crap who cares how close they are. If you have any info on these guys and their quality please let me know. Thanks, Dana |
| Chris Pincetich |
Jul 12 2007, 01:45 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I have a set of USED GT CF lids for my 914, normal headlight style, and they fit fine. My biggest beef with the used ones was the thread engagement for mounting to the hinges was bad, but that could be from the previous owner. I used some threaded inserts, washers, and some sanding to make mine line up better and fit tighter. If you remove all the lid springs first, it only takes 5 minutes to remove the hood - you should test fit them in the parking lot (IMG:style_emoticons/default/biggrin.gif)
I put a towel on the cowel at each corner to rest the hood lid on and not scratch my paint, then a prop rod under the hood to hold it up...in this position I can just swing the hinges up and bolt or unbolt them to the lid. (IMG:style_emoticons/default/beerchug.gif) |
| RON S. |
Jul 12 2007, 02:26 PM
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I bought my lid from Getty,it fit good enough for me,out of the box. Standard hood weight is around 35lbs.if I remember. The Getty was is 11lbs. Ron |
| sww914 |
Jul 12 2007, 03:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I've bought several parts from GT, I've been very happy. I have only ever seen one fiberglass part that fit perfectly, and it was from them. Most of the stuff fits OK to good, but not perfect.
I tried to fit a pair of doors from better bodies once that were so bad that we had to send them back. The second pair was just as bad. The bottom rear corner stuck out 2" from the quarter panel. Junk! |
| plymouth37 |
Jul 12 2007, 04:13 PM
Thanks for the info!
I have dropped 120 pounds so far just by unbolting and cutting off stuff I don't need. I will still have a full interior, just no extras like a radio, sound deadining, heater, door bars, windshieldwipers, etc... this is addictive! |
| TonyAKAVW |
Jul 12 2007, 04:27 PM
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I need to get back into this lens project. I'm wanting to do the headlight delete as well. Gotta get the last refinements made to the die and then get a whole batch of lenses up here.
-Tony |
| neo914-6 |
Jul 12 2007, 04:37 PM
Dana,
Another source that I almost used: Mark Bartosh PO Box 3432 Running Springs, CA 92382 909-867-9330 I highly recommend Mark's glass. He's the best quality for the least amount of dough. -Eric Shea Chris, I never bolt mounted those lids, in fact the PO Joe O used pins too and he bought them new. (IMG:style_emoticons/default/confused24.gif) Tony, Any idea when the die will be done? |
| 70Sixter |
Jul 12 2007, 04:39 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Many years ago I bought a factory front hood for my 911. It was so flimsy it indented at speed. Balsa reinforcement did not reinforce! Don't know if there were any factory 914 glass parts, but buyer beware.
| TonyAKAVW |
Jul 12 2007, 05:16 PM
Felix:
I dont know when the lenses will be done. I need to send my father in law a new lens so he can take some measurements. I just haven't gotten around to it. I'll see if I can get that over to the post office this weekend. Did you ever fire up the lights with those lenses yet? I saw the picture of them installed, but not with light coming out. I'm really curious to see what they do to the lighting pattern, if anything. -TOny |
| J P Stein |
Jul 12 2007, 05:39 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Sheridan. A CF/FG composit. The man takes pride in his work.
It is a race piece....no hinges/latches need apply. |
| neo914-6 |
Jul 12 2007, 06:12 PM
Felix: I dont know when the lenses will be done. I need to send my father in law a new lens so he can take some measurements. I just haven't gotten around to it. I'll see if I can get that over to the post office this weekend. Did you ever fire up the lights with those lenses yet? I saw the picture of them installed, but not with light coming out. I'm really curious to see what they do to the lighting pattern, if anything. -TOny Lit up I need to change the angle as they aim high, basically modify the bucket... |
| xitspd |
Jul 12 2007, 07:24 PM
Technology and Tradition 3.6 and 914-6 ![]() ![]() ![]() Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
We make a very nice unit (not currently for sale) however, I never have seen a complaint with Getty Design!
Dan |
| carr914 |
Jul 12 2007, 08:02 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,990 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
My Getty C/F fit like a glove. I always thought it would be easy to make 2 C/F pieces to fit the headlights.
T.C. |
| neo914-6 |
Jul 12 2007, 11:40 PM
You can also call Bontempi (HPH) about fiberglass parts. Those lids were light (had no structure)
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
