Paint touch up, Need some how-to's |
retrofit |
Jul 14 2007, 01:41 PM
Member Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 |
Doing some chip and ding repair. My paint is single stage so it's not too technical to repair.
The question is: How to deal with the "shotgun blast" on the nose. Lots of micro dings. Use a toothpick and put a drop of paint on each one, then carefully wetsand with 1000 or 1500, and then buff out like usual? Or should I spray the whole section doing a blend-in? What works best??? AK |
SGB |
Jul 14 2007, 03:00 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Microdrop on the toothpick is good, but you may not want to sand at all because it WILL show as a hazy area on the already cured paint. I've tried a fewe times to blend touch up, and only suceeded on a laquer finished early bmw in truely blending and leveling two paints, Just take a LONG time to fill each little hole. The paint should fill the hole up, and as it dries will shrink down and pull into the surface,. If it leaves a pit, do it again.
Lo-Fi Version | Time is now: 3rd June 2024 - 03:05 AM |
