6'r now has a harness bar, I installed a custom harness bar |
RON S. |
Aug 1 2007, 05:38 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Here's a few pics of a custom harness bar I put in the 6'r. Thanks go out to Chris Foley at Tangerine for forming it up. I had wanted one because I also want to add a pair of Sparco Pro 2000 seats. That,the seats,and a set of 5 point belts will round out the interior. The back pad is now history,and the rear firewall will be covered in Real German Perlon this weekend. Just one more step on the long journey. Ron Attached image(s) |
Chuck |
Aug 1 2007, 08:57 AM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
Ron,
That looks great! Are you planning on somehow bolting the harnesses to the bar or will you be using loops around the bar? I just picked up a set of used Sparcos and some 4 points from my brother last night that will be going into mine. Trying to decide whether to use a harness bar for the belts or to reinforce and bolt through the firewall. |
RON S. |
Aug 1 2007, 09:44 AM
Ron, That looks great! Are you planning on somehow bolting the harnesses to the bar or will you be using loops around the bar? I just picked up a set of used Sparcos and some 4 points from my brother last night that will be going into mine. Trying to decide whether to use a harness bar for the belts or to reinforce and bolt through the firewall. I'm gonna loop the belts over the bar.I have set the bar height pretty much level with the openings in the seatbacks. R |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:19 PM |
