Rear shifter bushing, Rear shifter bushing - in brass |
0396 |
Aug 14 2007, 12:56 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Not sure if this has been done.. has any one developed and or converted their
side shifter bushing ( where shift rod connects to cup /ball) to brass? part number 914-424-224-02-M100 on bird board. Mine has excessive clearance ie1-2 mm - thus when shifting in to 1st some times i will engage 3rd. Any suggestions is much appreciated |
Dr Evil |
Aug 14 2007, 01:48 AM
Yup, been done by a few. Searching will yield pics, too.
jasons |
Aug 14 2007, 07:32 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Patrick Motorsports sells a brass one thats oversize on the OD, since the hole is wallowed out so often.
http://www.patrickmotorsports.com/cgi-bin/main |
0396 |
Aug 15 2007, 12:16 AM
Patrick Motorsports sells a brass one thats oversize on the OD, since the hole is wallowed out so often. http://www.patrickmotorsports.com/cgi-bin/main Thank you! |
sww914 |
Aug 15 2007, 01:26 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
If you put it in backwards, you can't get it into some of the gears anymore. Don't ask me how I know.
0396 |
Aug 17 2007, 07:57 AM
If you put it in backwards, you can't get it into some of the gears anymore. Don't ask me how I know. I called Patrick and ordered a set. SWW914, can you expand your advice, are you saying that the circlip 'faces' to the rear of the car and does it come with simple instruction? Thank to all |
914werke |
Aug 17 2007, 02:42 PM
"I got blisters on me fingers" Group: Members Posts: 10,104 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Dont you mean self-lubricating Bronze?
Lo-Fi Version | Time is now: 29th May 2024 - 02:21 AM |
