> Carb fuel pump power problems
bdstone914
post Sep 17 2007, 06:31 PM
bdstone914
Where is the best place to get power from for the carb fuel pump. No more fuel injection stuff. PO had run a hot wire and a switch from the battery and I do not like that setup. All help appreciated. Thanks
Replies(1 - 4)
911quest
post Sep 17 2007, 06:40 PM
QUOTE(bdstone914 @ Sep 17 2007, 04:31 PM) *
You mount it using tha factory wires and make a jumper across the the rleay board side of the fuel injection connector and it will run with the key on ( normally)
bdstone914
post Sep 17 2007, 06:55 PM
bdstone914
Exactly which two points need to be jumped? I know which wires go to the fuel pump just not which point to jump with the + terminal to get power.
bdstone914
post Sep 17 2007, 07:11 PM
bdstone914
http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php solved my problem
purple
post Sep 17 2007, 08:18 PM
Pigeon feeders attract me
and when you get that sorted out... cousin brucey here makes some awesome rebuilt pedal sets!
hehe, pluggin your work bruce
- Lo-Fi Version Time is now: 11th July 2025 - 02:35 PM
