trailing arm bushing Q again!, should the shaft rotate? |
toon1 |
Sep 20 2007, 03:35 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Should the shaft of the trailing arm roatate in the stcok bushings?
I tried to turn the shaft and it does not rotate. |
Joe Ricard |
Sep 20 2007, 03:51 PM
Nope they are bonded together
Mueller |
Sep 21 2007, 04:50 AM
Should the shaft of the trailing arm roatate in the stcok bushings? I tried to turn the shaft and it does not rotate. I believe the original design was for the rubber to "twist" and give a little, but not to allow the shaft to rotate inside the bushing... i don't think they are bonded or vulanized to the shaft...just really tight fit.. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:14 AM |
