914/6 Transmission Question, why a shorter 5th gear? + more trans gear talk |
McMark |
Sep 28 2007, 02:51 AM
I'm looking at 914/6 transmission gear ratios because I have one in my shed. I'll be the first to say that transmission gearing is not my strong suit. (IMG:style_emoticons/default/wink.gif) According to Charlie Davis the 914/6 transmission has:
1st: Same 2nd: Taller 3rd: Taller 4th: Same 5th: Shorter I'm not sure why the 5th would be shorter. My guess would be to keep the 6 cylinder revs up for cooling as well as to keep it in the high 6 power band. Am I wrong? If I rebuild this tranny to mate with a 2270, I'm thinking that it would be smart to put the 4 cylinder ZD 5th on there since I'll have plenty of torque down low. |
ClayPerrine |
Sep 28 2007, 07:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I'm looking at 914/6 transmission gear ratios because I have one in my shed. I'll be the first to say that transmission gearing is not my strong suit. (IMG:style_emoticons/default/wink.gif) According to Charlie Davis the 914/6 transmission has: 1st: Same 2nd: Taller 3rd: Taller 4th: Same 5th: Shorter I'm not sure why the 5th would be shorter. My guess would be to keep the 6 cylinder revs up for cooling as well as to keep it in the high 6 power band. Am I wrong? If I rebuild this tranny to mate with a 2270, I'm thinking that it would be smart to put the 4 cylinder ZD 5th on there since I'll have plenty of torque down low. I have the guts from a /6 tranny in my garage. The factory reason was to spin the fan faster to compensate for the 10 degrees hotter the engine ran in a 914 chassis. They also changed the redline on the temp gauge because it ran too close to the original line. |
Eric_Shea |
Sep 28 2007, 10:51 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) Clay is spot on.
I'm putting that gearbox you tore apart back together via Evil and I'm thinking ZD but I have my reservations. 1. That 2.5 runs hot in my 911 with a jailbar front cooler. 2. Now put it in a teener... I'll have the front cooler which is ducted and radiator style vs. the jailbar in the fender well so I think it will be OK. Thoughts? ZD or...? I spoke with a friend who has a factory 2.0 twin plug teener and his tranny had the 904 shaft and 912 gears. How does the ZD compare to the 912 final? |
DanT |
Sep 28 2007, 10:55 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
and the fact that the 911 engine had about a 1,000rpm higher redline and cruising torque was not as good as the 2.0L 4s. (IMG:style_emoticons/default/smile.gif)
Eric_Shea |
Sep 28 2007, 10:58 AM
I have an 8,000rpm redline and no torque. Now what?
ClayPerrine |
Sep 28 2007, 12:09 PM
I have a ZD fifth in my 914/6. It runs at 3k at 70MPH all day long with a 190 degree oil temp.
But I have a 911 Carrera cooler mounted in the right rear corner with the fan hooked up. |
McMark |
Sep 28 2007, 12:12 PM
Front cooler = freedom. I wouldn't worry about heat. Plus you can always upgrade to a larger cooler.
But if you want my ZA gear Eric, we can probably work something out. (IMG:style_emoticons/default/wink.gif) |
TravisNeff |
Sep 28 2007, 12:13 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
McMark |
Sep 28 2007, 12:21 PM
912 4 or 5 speed final is X 28:24 (0.8571) versus the ZD 31:22 (0.7097) and the ZA 29:22 (0.7586), so it's even shorter than the ZA, by quite a bit. The 912 5 speed is you MSX gear source. (IMG:style_emoticons/default/wink.gif)
McMark |
Sep 28 2007, 12:32 PM
What about a D first gear for a torquey 2270?
Eric_Shea |
Sep 28 2007, 06:00 PM
QUOTE But if you want my ZA gear Eric, we can probably work something out. OK. (IMG:style_emoticons/default/biggrin.gif) QUOTE The 912 5 speed is you MSX gear source. I'm a gear dummy. What does that mean? |
sixnotfour |
Sep 28 2007, 07:27 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Six Gear Chart
Attached image(s) |
sixnotfour |
Sep 28 2007, 07:39 PM
Four geras are ; A-F-N-V-ZD
Attached image(s) |
Brando |
Sep 28 2007, 07:44 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Real reason was: To not be as fast as Porsche's 911 flagship.
You can take that as subjectively as you want. Why is a boxster engine 'detuned' compared to a 996 engine of same displacement? |
McMark |
Sep 28 2007, 07:53 PM
QUOTE The 912 5 speed is you MSX gear source. I'm a gear dummy. What does that mean?1st: A - stock first gear 2nd: F - stock second, which is part of the mainshaft 3rd: M - shorter than stock 4th: S - shorter than stock 5th: X - shofter than stock The stock 912 five speed has MSX gears for 3,4,5. So if you were building an AX box, then a 912 five speed would be your donor trans. (IMG:style_emoticons/default/wink.gif) |
Aaron Cox |
Sep 28 2007, 09:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
gear chart time bitches....
(this is for my car... but the ratios are shown... the MPH will be off by a few % due to my tire sizes) Attached thumbnail(s) |
brant |
Sep 28 2007, 09:43 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
MSX can be fine
but they are kinda tall for a -6 they are really better suited to the -4's because the -4's often have a lower redline MSX is great for 6K or even up to 7k above 7K they are too tall choosing gears is kinda like jakes description of a complete system it depends completely upon your redline, track length, wheel sizes, torque curves, etc when you start reving a motor over 7 and up to 8+ you really need shorter gears than MSX I ran MSX (well actually Ka, S, X) on both a -4 and my current 911S motor at 7300. You wouldn't believe the difference when I went to the FJOSV. With the MSX I couldn't even use the X and S was even too long of legged for above 7K brant |
Eric_Shea |
Sep 28 2007, 11:23 PM
I'm starting to catch on with Brant's description and Boy-Wonder's chart... especially given the engine I have. It doesn't wake up until after 4k and would top out over 8.
Johny Blackstain |
Sep 29 2007, 08:42 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I too, run @ 3K RPM doing 70mph. No oil cooler up front, yet, so I've run around 205*/210* this summer. However if I drop down to 60mph the temp drops dramaticaly: 180*/190*.
Never goes over 200* in the winter no matter what my speed. No idea what my gear ratios really are- supposed to be the same as a 906 (IMG:style_emoticons/default/blink.gif) . |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:56 AM |
