| mrhurtalot |
Oct 1 2007, 04:11 PM
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
so my rear left brake is really tight, like the brakes not engaged, but its still hard to turn the hub. possible culprits? ill be going home tonight to finish up the radio install and shift alignment.
| davep |
Oct 1 2007, 04:26 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,363 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Could be a lot of things:
stuck cable holding it on pads stuck in the caliper pistons stuck in the bores rubber brake line pinched inside holding pressure on Check each one out, then we can help with solutions |
| rascobo |
Oct 5 2007, 01:28 PM
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
Could also be incorrect venting clearance.
| McMark |
Oct 5 2007, 01:57 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
(IMG:style_emoticons/default/agree.gif) with both
Lo-Fi Version | Time is now: 30th May 2026 - 10:09 PM |
