Fuel Filter Replacement, hose question |
mdwman |
Oct 3 2007, 07:25 AM
Member Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 |
I am planning to replace the fuel filter on my '73 1.7 this weekend and need to go ahead and replace the fuel hoses that connect the filter as well. I've searched previous posts and the diagram on PP for the type hoses and see that the hose from filter to fuel pump is 7mm high pressure but the tubing from filter to fuel line is referred to as an "intake pipe" and has a different diameter on each end. Is this part an actual hose like the fuel hose or is it a rigid pipe?
Also, any tips on getting good access to the filter? It sure is tucked up there under the right side! Thanks in advance for any help. |
Brian_Boss |
Oct 3 2007, 08:40 AM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
It is rubber - basically a stepped diameter piece of fuel hose.
Lo-Fi Version | Time is now: 1st June 2024 - 08:39 AM |
