Alien autotopy pics! |
rick 918-S |
Oct 12 2007, 09:38 PM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I stopped at my local machine shop to check on the progress on my head repair.
The first of four photos is the exhaust valve punched into the head splitting the intake seat. (Very hard!) The valve was punched into the head about 3/4" The port was split and buldged. Attached image(s) |
rick 918-S |
Oct 12 2007, 09:39 PM
Here's the buldged and split port.
Attached image(s) |
rick 918-S |
Oct 12 2007, 09:41 PM
Here's the port after the repair. Very deep split and very diffecult to tig.
Attached image(s) |
rick 918-S |
Oct 12 2007, 09:43 PM
Here's the combustion chamber. There is some work left but were getting close.
I'm very happy so far. Attached image(s) |
skline |
Oct 12 2007, 10:07 PM
It wasn't cheaper and faster to buy a replacement head? Seems like a lot of expensive work.
brp986s |
Oct 12 2007, 10:18 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
what caused it in the first place? iirc, you had just started from cold when this happened. Do both heads need to be reblt?
rick 918-S |
Oct 12 2007, 10:23 PM
It wasn't cheaper and faster to buy a replacement head? Seems like a lot of expensive work. Here's the problem. I brought these heads to a shop that specializes in heads. They told me $ 900.00 Plus parts. Considering these heads had been repaired and cut I asked the specialist if he could tell me if the heads had been cut too much already. The guy didn't know how to check. I gave him instructions on the method to check them. Turns out they are on the limit. I purchased a replacement set of used heads for $ 1000.00 (needing a valve job) After my specialist experience I decided to educate the local shop. They checked the heads I bought and discovered they had been cut below spec. So, back to getting mine repaired. These heads are euro spec "S" heads. The ports are bigger, the valves are bigger, the combustion chambers are smaller. The euro "S" heads are like rectangle port closed chamber Big Block Chev heads The US heads are like oval port open chamber Big Block Chev heads |
rick 918-S |
Oct 12 2007, 10:27 PM
what caused it in the first place? iirc, you had just started from cold when this happened. Do both heads need to be reblt? I'm still not sure. (IMG:style_emoticons/default/confused24.gif) After attempting to get some info from the List I'm back to square one. All I can say is when this thing goes back together I'll be checking everything. |
iamchappy |
Oct 12 2007, 10:51 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I believe in aliens, proof enough for me.....
JPB |
Oct 13 2007, 07:21 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Looks like ya gonna get it. That is such the tempting build. (IMG:style_emoticons/default/beer.gif)
jim912928 |
Oct 13 2007, 07:23 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Rick,
Not sure if you saw this link on pelican 928 forum...but it was someone looking for a spcecific 928 machinist/engine builder that resides in Wisconsin....here is the thread to find out the contact info (just in case you need more work by someone in the 928 world). http://forums.pelicanparts.com/showthread....light=wisconsin Jim |
spare time toys |
Oct 13 2007, 05:03 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Here is the link to his 427 CID 928 engine (IMG:style_emoticons/default/aktion035.gif)
http://www.erik27.com/todd/ |
Lo-Fi Version | Time is now: 10th June 2024 - 02:44 AM |
