Handbrake Warning Light problem |
jonferns |
Nov 4 2007, 03:27 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
well, I dont really know if its a problem, but I replaced the bulb for the handbrake warning light...when the key is in the "on" position (but the engine not started), the light flickers, and there is a noticable buzzing sound. When the handbrake is released (engine still off), the light turns off, like its supposed to, but when you press the brake down to a certain point, the light flickers once again.
When the engine is turned on, everything is fine. My question is whether this is/can be a problem? any ways to fix it? thanks! -JON (IMG:style_emoticons/default/driving.gif) |
euro911 |
Nov 4 2007, 05:30 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Check sensor on your master cylinder, you may need to bleed it (IMG:style_emoticons/default/confused24.gif)
Attached image(s) |
swl |
Nov 4 2007, 05:32 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Isn't that light also associated with master cylinder? maybe try the reset switch on the master cylinder?
Lo-Fi Version | Time is now: 10th June 2024 - 10:19 AM |
