/6 oil filter question, what size? |
Dr Evil |
Nov 29 2007, 02:48 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have a stock oil tank with an aftermarket oil filter mount. I know that the ones some recommend have too large of an opening for the screw mount. The one that was on it before and the replacement are P-65, but pelican does not list this size for replacement, only OC-61 and others. I am confused as to what size I need. Help!
Eric_Shea |
Nov 29 2007, 03:33 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE aftermarket oil filter mount Weird. I didn't know the mounts were ever made by anyone else. Measure and I'll let you know (I have one of each). If some are too big I would guess you have the early style that is stock for a -6 or say... a 1970 911 |
Dr Evil |
Nov 29 2007, 03:36 PM
I got my mount kit from Rich Johnson that also makes the /6 engine mount that I bought. Nice guy, good stuff (IMG:style_emoticons/default/thumb3d.gif)
sixnotfour |
Nov 29 2007, 03:39 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
small thread oc-61 is the one you need for a factory -6 tank.
big thread oc-54 is the late 911 or vellios i think uses. there is a 73 911 oil filter adapter that is like the -6 and early 911, but has the big thread, kinda rare. what you have , dunno ? |
Eric_Shea |
Nov 29 2007, 03:42 PM
(dig through your rubble pile and find the man some hot P&C's and cams!) (IMG:style_emoticons/default/biggrin.gif)
Dr Evil |
Nov 29 2007, 03:47 PM
Shut up monkey boy! (Eric)
I'll measure the opening and look at the threads. I think it will be stock /6 and that the big ones I have found were for the later 911. The filters I had were from a parts stash my friend left me. |
sww914 |
Nov 29 2007, 05:34 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I've seen OC 54 and OC 61 on -6 conversions. I don't remember which filter fit which type of tank because I didn't need to know so I didn't look. I wouldn't remember anyway cause I can't remember shit, so I write it down when I remember to.
rfuerst911sc |
Nov 29 2007, 07:25 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I just ordered from Pelican the OC61 to fit my DW Design tank. I was told the DW tank takes the OEM OC61 filter. I guess I'll see when they show up as I haven't installed the tank yet.
Eric_Shea |
Nov 29 2007, 09:05 PM
The tank doesn't take anything. The filter console that mounts on the tank does.
sixnotfour |
Nov 29 2007, 09:47 PM
The Vellios tank, it screws right to the tank. No adapter.
OC54 has 25mm threads OC61 has 19mm threads |
Dr Evil |
Nov 30 2007, 09:53 PM
OC61 it is. I measured 17.88mm on the inside diameter of the filter, but the threads will of course be larger. AND, printed on the base of the filter was 3/4 (= 19mm). The others that I tried had to have been the 25mm because they were huge. Also, I was a bit stupid in that I was trying to get a 74 filter for my engine not realizing until now that the tank is a 70 (DUH).
Lo-Fi Version | Time is now: 5th June 2024 - 06:21 AM |
