Momo Steering Wheel, Installation Question/Problem |
rwjames |
Jan 30 2008, 07:26 PM
Member Group: Members Posts: 326 Joined: 2-June 06 From: Montgomery, AL Member No.: 6,136 Region Association: South East States |
My wife got me a Momo Race steering wheel for Christmas for my 1973 914 2.0.
The hub is the Momo 8002, Performance Products p/n 908253. I removed the turn signal cancel ring from my original wheel and installed it on the Momo adapter. Attached the wheel to the adapter and slipped it on the shaft, putting the washer and nut over the Momo adapter. I snugged down the nut and the bottom of the Momo adapter fit so tight against the steering column, I couldn't turn the wheel. Thinking Performance Products sent the wrong adapter, I ordered another one with the same issue. Anyone have any ideas? |
markb |
Jan 30 2008, 07:38 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
It sounds like you need a spacer.
will |
Jan 30 2008, 07:39 PM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
looks like you have the right part. make sure you don't over tighten the nut. also make sure the splines line up, forcing it could strip your shaft and your hub might also get stuck.
John |
Jan 30 2008, 07:55 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I think I have a circlip installed on the shoulder just below the splines on the steering shaft. Without the circlip, mine did the exact same thing that you are describing.
Let's look for a pic..... It may be a little hard to see in the pics, but it is there. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 09:50 AM |
