> That can't be good! Holy mother of melted wires ..., or, what happens when your alternator burns up ...
post Feb 10 2008, 06:55 PM
Resident German
(IMG:style_emoticons/default/icon8.gif) got the new alternator and decided to cut back the plastic sheeting around the alternator wires to see how much damage then burned up diode had done.
i guess a lot of current while draining the battery can really produce some heat ... (IMG:style_emoticons/default/headbang.gif)
so, now the $432 dollar question, is there a replacement harness for this or do i have to either get a complete new engine harness or try to replace each wire individually?
they're pretty much burned all the way into the main harness. i cut out the worst, but the insulation where i cut them was still very hard and brittle, so i'm guessing the whole of the wires is toast ...
this is on the 3.6L engine, btw. ...
(IMG:style_emoticons/default/blink.gif) Andy
Replies(1 - 15)
swl
post Feb 10 2008, 07:01 PM
Whoah! That must have been exciting.
You would have to think that the entire wire is fried - it was probably carrying the same current along it's entire length.
crash914
post Feb 10 2008, 09:03 PM
its a mystery to me
duct tape (IMG:style_emoticons/default/wink.gif)
McMark
post Feb 10 2008, 11:04 PM
914 Freak!
A new harness is probably expensive, but rebuilding the harness would take all day to do nice and clean (proper connectors, proper wires, proper sheathing). I vote buy.
Jeff Hail
post Feb 10 2008, 11:08 PM
I am interested in how your system is grounded? A 3.6 carries a significant amount of more amps than a type 4 motor does. Assuming your trans is grounded by the pre-requisite earth strap what about your front motor mount to chassis? Battery negative to chassis and case? It is apparent once the diode went an over-charge condition resulted in the melted insulation.
Grngoat
post Feb 10 2008, 11:23 PM
Lurker Member
Looks like Rich Johnson is selling a nice new one on ebay. $250.
ebay
I seem to remember that there was a recall on the 993 engine harness at some point because of fires. That could've been bad.
rick 918-S
post Feb 11 2008, 11:25 AM
Hey nice rack! -Celette
Wow Sir Andy! That's really bad! But that could have really worst! (IMG:style_emoticons/default/blowtorch.gif) Buy the harness check to see the grounds are good and be done with it.
post Feb 11 2008, 12:26 PM
Resident German
QUOTE(Grngoat @ Feb 10 2008, 09:23 PM) *
yepp, turns out, my harness is the old one. looks like, the PO never took his car in to have it replaced ...
new harness it is!
(IMG:style_emoticons/default/piratenanner.gif) Andy
JeffBowlsby
post Feb 11 2008, 02:34 PM
Yipes Andy!
If the damage is not too bad, maybe a few wires/casing can be replaced easily enough. The Rich Johnson harness looks like a great deal if you are in a hurry.
If you do replace it, would you donate it to me for 914 harness science?
post Feb 11 2008, 04:44 PM
Resident German
QUOTE(Jeff Bowlsby @ Feb 11 2008, 12:34 PM) *
sure thing ... (IMG:style_emoticons/default/beerchug.gif)
a little bird just told me that the new harness from porsche is $775 ...
(IMG:style_emoticons/default/huh.gif) Andy
crash914
post Feb 11 2008, 06:58 PM
its a mystery to me
can you get a warranty replacement? if this was the defective harness?? worth a try..
post Feb 11 2008, 10:13 PM
Resident German
QUOTE(crash914 @ Feb 11 2008, 04:58 PM) *
nope, no dice. the recall is for the cars. they will only honor the recall if i can give them the VIN of the 993 the engine came out of ...
(IMG:style_emoticons/default/dry.gif) Andy
post Feb 12 2008, 03:55 PM
Resident German
picked up the new harness today and i got a smoking deal on it!
genuine porsche replacement harness bought directly from the dealer for $115 !
(IMG:style_emoticons/default/beerchug.gif) Andy
PS: Jeff, please PM me your new address so i can send you the old harness ...
horizontally-opposed
post Feb 12 2008, 04:54 PM
"genuine porsche replacement harness bought directly from the dealer for $115"
Flippin SWEET! (IMG:style_emoticons/default/w00t.gif)
pete
McMark
post Feb 12 2008, 05:25 PM
914 Freak!
That's awesome. (IMG:style_emoticons/default/smilie_pokal.gif)
PRS914-6
post Feb 12 2008, 05:35 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
Here is a little more info. There was a recall on the engine harness for 95-96. The dealers had harneses (normally about $800.00) for $115.00 to be billed out for the recall cars. Must have been a bean counter deal. Andy, good job on the score. The recall harness is identical to a harness you would buy except the part # on the box should start with 000. Inside the box is the same harness though with the right part #....go figure
Here is the bulletin info. Those that have 3.6 engines can back-track the engine # to get the VIN number and ultimately see if your engine is suspect.
- Lo-Fi Version Time is now: 26th September 2025 - 06:41 AM
