| stephenaki |
Feb 18 2008, 11:57 AM
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I went to Cologne this weekend and on the way up stopped by to see Ingo at Mittelmotor to see what the deal was...I was prepared for the worst based on his email.
Well, based on his email, and some information from this forum, it is not near as bad as I feared. Let me summarize this and get to the point and, I will need some input from the group on some issues. 1. Diesel problem, fixed. They changed out 3 of the plugs, one was stubborn so they decided better I break it than them, and fuel filter. Runs fine now. 2. Front axle not a problem, he thinks the shocks should be changed. Otherwise the tierods and A-arms were solid. 3. Brake lines. Fairly well worn and the lines from the metal tubing to the brakes definately need replacing. 4. Engine and Gear Box leak. Need to replace some seals, nothing that requires the engine to be dropped. 5. Lights and wipers. still inop and the lower right fog?driving light? is busted. 6. Engine mounts need replacing. All four are worn and the rubber cracked. 7. Rear axle (this had me worried). It IS attached to the car. What he was refering to was that the trailing arms had lateral play and he said that the pin that runs through it was bad and the entire trailing arm should be replaced on both sides. So, here are my questions, most serious concern first. 1. Trailing arm lateral play, whats tolerance? Can the pin be replaced or do I have to replace the entire trailing arm? (IMG:style_emoticons/default/confused24.gif) From what I can see, the whole unit must be replaced. This would be the most expensive problem. 2. Lights, what are common problems that people have experienced that would cause the headlights and driving lights to shut down? All the other lights and turn signals work. Bottom line, not that big a problem, the cost was going to be the labor, they charge A LOT!! Needless to say brakes are PITA and I didn't feel like messing with the seals so I had him fix those two problems. If I had my Mityvac I would have done the brakes but I don't and I hate bleeding brakes! I go back next Saturday to pick up the car, I will put her on a trailer and bring it back to Stuttgart then drop it off at the on-post auto craft shop and work on it there. Barring any significant issues with the trailing arms, need your input on this one, I should have it up and ready for inspection before the end of March. (IMG:style_emoticons/default/driving.gif) Of course this could all come to a screeching halt if they send me on another lovely trip somewhere else for a few weeks but I don't think that is in the cards right now. (IMG:style_emoticons/default/av-943.gif) |
| rhodyguy |
Feb 18 2008, 12:11 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
shot bushings/pin on the trailing arms? look at the elephant setup (eric shea offers them done) but he has done a nice write up on how-to yourself. an alignment will be required. chris foley offers a delrin(?) replacement set as well.
you can do the mounts yourself both outboard fronts and the rears. year specific. avail at pelican and other vendors. wipers? check the fuse. the lights don't raise or don't illuminate. don't raise? suspect the relays. check fuses then the headlights. sealed beam or halogen? the fog/driving lense is easily replaced if that's what's wrong. |
| stephenaki |
Feb 18 2008, 12:31 PM
shot bushings/pin on the trailing arms? look at the elephant setup (eric shea offers them done) but he has done a nice write up on how-to yourself. an alignment will be required. chris foley offers a delrin(?) replacement set as well. you can do the mounts yourself both outboard fronts and the rears. year specific. avail at pelican and other vendors. wipers? check the fuse. the lights don't raise or don't illuminate. don't raise? suspect the relays. check fuses then the headlights. sealed beam or halogen? the fog/driving lense is easily replaced if that's what's wrong. Lights raise, don't illuminate. Checked all the fuses, unless there are some hidden other than under the dash, they are all still good. Ugly, but good. |
| TeenerTim |
Feb 18 2008, 12:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
Never overlook the obvious. The bulb may be burned out.
| stephenaki |
Feb 18 2008, 12:47 PM
| r_towle |
Feb 18 2008, 01:38 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Lets see,
Oil leaks, motor mounts, bad plug...take out the motor to fix these all at the same time. While the motor is out. Trailing arm typically wears out in one place...the hold in the suspension ear either ovals out, or the suspension console rusts out and it really worn and then it will wobble on the highway. So, first thing to try...have him tighten the inner trailing arm nut back to spec...see if it tightens up the arm. Wearing out the pin...wont happen. Its hardened steel that will beat the suspension console both inner and outer apart before it wears a bit. Rich |
| Eric_Shea |
Feb 18 2008, 03:11 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Wearing out the pin...wont happen. Its hardened steel that will beat the suspension console both inner and outer apart before it wears a bit. Well... true, we rarely see "wear" as an issue here but we do see "rust" and "rust pits" on the shaft often. Hardly what I would call indestructable. Roughly 25-30% of the arms I see have this problem. I have the shafts in a pile to prove it. The point I see is, a rust pit hidden under the bushing rubber would be almost impossible to diagnose. And... it doesn't diagnose as they mentioned, so, I'm not at all convinced of this bizaar diagnosis. Someone needs to explain "Lateral Play". Lateral play at the shaft is virtually impossible. One end is bolted to the inner suspension ear with a 22mm lock nut. The other is bolted through the outer console mount with another 22mm lock nut, that mount is then bolted to the body with 3 17mm bolts. If the 22mm nuts are tight and the console mount is tight... there can be no lateral play. Worn/rusty shaft or not. Rich is correct about the wear. If the 22mm nuts are not at spec, the suspension ears have been known to "oval". This, again, would have nothing to do with your control arms. On rare occasions I have seen suspension shafts where the bushings have crumbled or deteriorated. This could lead to lateral "end play" of the control arm. Still... extremely rare. Youwould know it as you would have major clunking noises coming from there. I don't like this diagnosis at all... (IMG:style_emoticons/default/idea.gif) I'd be willing to bet your control arms are f-i-n-e, fine. I havent seen very many stock arms that would not drive and drive a good long time. Even with rusted shafts. |
| Bleyseng |
Feb 18 2008, 06:45 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/agree.gif)
When I visited in 2004 some of the guys I talked to were really up on 914's and the rest had no clue. I was really shocked how much they didn't know about Djet. (IMG:style_emoticons/default/popcorn[1].gif) |
| rick 918-S |
Feb 18 2008, 06:53 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,243 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I wouldn't put any stock in a visual inspection of the fuses in the holder. Specially if the lights worked then didn't. I would check the hot side with a test light or volt meter. I have seen the brass holders tarnish over and cause a mis-connection. The fuse will look good but not carry current. I would see if you have power to the hot side of the fuse first thing. BTW: It's easy to kick the fuse holder and knock fuses right out of the holder while getting in the car. Ask me how I know... (IMG:style_emoticons/default/dry.gif)
I agree on the trailing arm pin. It's highly unlikely the mild steel mounting hole wore the hardened steel pin... (IMG:style_emoticons/default/bs.gif) I would even go as far as removing the inner nut and checking to see if the hole is oval shaped. If it is, it's a fairly easy fix with a welder and a file. |
| stephenaki |
Feb 19 2008, 12:58 AM
Thanks to all for the responses, I am thinking of upgrading the fuse box with the kit that Pelican sells, anyone do that?
As far as the trailing arm, I will have a much better idea when I get her back this coming weekend. If the holes have 'ovaled' what is the procedure for the fix? I am hoping it is as simple as tightening the nut to specs as mentioned, am I correct in assuming my Haynes manual will have the correct specs for this adjustment? I am feeling a lot better about what needs to be done with everyone's input, not near as catastrophic as I had imagined. |
| hcdmueller |
Feb 19 2008, 04:22 AM
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England
| stephenaki |
Feb 19 2008, 04:49 AM
Thanks Chris, the Navy guys in Italy pretty much busted the rear release in the process of trying to figure out how to open the rear trunk. I am eyeing up both the rear trunk release kit he sells and the fuse block he has. |
| rick 918-S |
Feb 19 2008, 08:20 AM
Someone should post a photo of a suspension console with an oval'd hole. I think there is even a post on this site someplace showing the repair. But you should be able to weld the oval spot and grind it and file it back to spec.
Someone will post a pic. I don't have any. |
| Eric_Shea |
Feb 19 2008, 11:45 AM
We don't know if that's the problem.
I searched (+oval +suspension +weld) and couldn't find anything. I did find this though. This is one of the rare bushing collapses: http://www.914world.com/bbs2/index.php?sho...eld++suspension |
| stephenaki |
Feb 19 2008, 01:33 PM
We don't know if that's the problem. I searched (+oval +suspension +weld) and couldn't find anything. I did find this though. This is one of the rare bushing collapses: http://www.914world.com/bbs2/index.php?sho...eld++suspension I did a similar search but I can't remember the words. I found a thread on the use of a washer to fix the problem. Had a lot of input from you as well Eric. Basic jist was to weld in a washer with the appropriate diameter to fix the problem. The discussion tthen progressed to, "where" outside or inside, trailing arm stud length, and the alternative of cutting the metal to the outer diameter of the washer then welding to ensure proper fitment. Quite interesting. I am hoping I can get a good look at her this Sunday when I get her back from Mittelmotor. In the interim, I am going to order a fuze block upgrade to start with then, after I assess the rest of the car, set up my priorities of work that will get it past inspection first then improve overall handling and ride. |
| jd74914 |
Feb 19 2008, 06:46 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
If you are going to get a new fuse block get the new stile upgrade from Engman . . .
http://www.engmanparts.com/electrical.php |
| stephenaki |
Feb 22 2008, 01:27 PM
Picked up a car and trailer today; will be off to pick up the teener tomorrow morning and then take it to the car craft location.
Ingo sent me an email, brakes are good and seals are good however, she is only firing on 3 cylinders. Culprit seems to be the plug he could not get changed out. Guess I will have to work that one when I get her back tomorrow. Will take the camera and get some pictures. |
| Jeffs9146 |
Feb 22 2008, 05:41 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Ovaling before repair and after repair!
| stephenaki |
Feb 23 2008, 01:34 PM
| stephenaki |
Feb 23 2008, 02:02 PM
Ya know, the Army has a saying, "no plan survives first contact." Yeah, the plan to bring the car back didn't go as...well...planned. But it did get done.
Picked up the rental car and trailer yesterday. First problem, the car has a hidden hitch, it was a full size Audi station wagon, and the rental car girls can't figure out how to make it reveal itself. Well after about 10 minutes they decide to read the manual. TA DA!! They got it to work, hmm wouldn't the manual be the first place to start? So, go and pick up the trailer, get there and they first have to figure out how to use the Value Added Tax (VAT) form (this negates me paying the high German taxes) and then they tell me the don't take credit cards. So off I go to find an ATM and come back. OK were ready, back the car up, hook her up, check the lights, look at the guy, "It's OK?" He says yes, now mind you, he hooked everything up but didn't explain anything. No problem, had a trailer in the states... Take the car and trailer to post and park it; will ride my bike to post in the morning and take off from there. The rental car place is right outside the gate so when I drop the car off, I walk onto post, get on my bike and ride on home. So I wound up getting on the road at 0600 this morning, all is good. around 0730 I am in the middle lane and getting ready to get over. German flashes his lights at me from behind. Hold on bubba, I am moving over but there was a car in that lane a bit ago! As he pulls past me he slows and matches my speed, I look over anticipating him yelling at me through his closed window, not quite. He is signaling that something is wrong with the trailer. Crap; drive another couple hundred meters till I can pull over onto the shoulder then pull off and stop. Put on my hazards, get out and look at the trailer, what the hecks the problem? Can't see any problem, uh oh, found it. You know the front wheel on the trailer's third leg that keeps the tongue from resting on the ground? GONE!! Evidently knucklehead at the trailer rental place failed to wind it up into the fully locked position and the jostling bounced it down until the wheel was running on the road at 140 km/h. So I wind the wheel all the way up until it is locked; should have checked but I figured the guy said everything as good. No other problem. Get to Mittelmotor, rather uneventful, got some pictures of their racer that I will post later. Load up the car, strap her down and away we go back home. By the way, the full size Audi diesel wagon? Great car! So I am on my way, I don't make it but 10 kilometers on the autobahn when the polizei pulls in front of me and has the little scrolling words in between his lights that say, "Bitte, Folgen." Mein Deutsch ist Nicht gut, but I figured that out. So I follow him and we pull over. What the heck is wrong?! I wind up getting out of the car and going back with him to the trailer where he shows me this wire that is looping around the lever to lock in the trailer receptacle to the ball hitch. OK, so what? It is evidently the emergency safety wire that triggers the trailer emergency brake in case it breaks away from the vehicle. Again, so what? It is improperly routed. Remember earlier about not getting anything explained to me... Normally, this is a 50 euro fine but after some discussion they both come to realize I had no idea that this was a problem and I explained to them that the trailer guy said jack and squat about the set up. So, the guy decides he is going to fine me only 30 euro and did I have 30 euro on me. For those that haven't been to Germany, the Polizei can fine you on the spot. You pay them and they write up the ticket and a receipt. Well, I happen to have 30 euro; no big deal beats 50. So the guy goes back to the squad car and gets his ticket book then comes back over to me to see if I have 30 euro, I tell him yes. He pulls out the book and his partner walks up. They have a discussion. Evidently they can't figure out how to write the ticket so, decide to just give me a warning but, before they go, I have them check to make sure nothing else was wrong. No more issues the rest of the trip but I didn't make it home until almost 1800 today. I did call the trailer guys about the wheel and told them I would come see them on Monday to talk to them about it. I don't want to be charged for something that they did. The car is now at the autocraft shop and I will head over there tomorrow to do an assessment. The one guy that works there thinks the cylinder head is loose which is why she is blowing a lot of smoke. I don't see any way to tighten and check torque WITHOUT dropping the engine; anyone got any suggestions? Now the work really begins. |
Lo-Fi Version | Time is now: 14th April 2026 - 06:53 PM |
