Monza 4 tip, modifying it |
Ray Warren |
Jan 11 2004, 06:12 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
i have a new rear valance to install (no cut out for exhaust).
i was thinking of removing the inner tips of the muffler and straighten out the remaining two so that they are not pointing up. has any one done this? Attached image(s) |
914ghost |
Jan 11 2004, 07:03 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
Y'know, they make a 2-tip "monza", I think Thunderbird makes it. I think the pipes exit from about the same spot, but theres only 2 of em' and theyre a little straighter.
I know where theres a used one I was thinking of sporting. Might be a bus exhaust, may still work I'll have to check, but what you wanna do sounds fine to me. .what about the extra holes? weld em shut? Might work! Robert O |
rhodyguy |
Jan 11 2004, 07:37 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if the valance is fibre glass i would notch that. if you lower the tips much they will scrape when you go up or down a steep incline, maybe tall speed bumps. do you plan on running the monza a long time?
kevin |
seanery |
Jan 12 2004, 07:20 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I did that same thing to mine. I GOT A TRIAD (IMG:style_emoticons/default/laugh.gif)
that's my recomendation. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:52 AM |
